Tip & How-To about Audio Players & Recorders
How to Put Load(s) of Music on Ipod Chromatic
HELLO,
This will show you how to use minimum space to have maximum music files on you Ipod Chromatic.
STEP 1: Locate all your music files that you want to upload on you iPod.
(Using Either PC or MAC )
STEP 2: Categorize and name a folder, called musice. If you have
different music files, name other folders music 2, (for mp3)
music 3, (for wma), etc...
STEP 3: Put the different music files in their seperate folders. And then
put all those folders in the main folder called Music.
STEP 4: Plug in your Ipod, and run it in My Computer. Click on the
Music folder, (If using Windows: >>> Right ~ Click on Taskbar
and Click Tile Windows Verticlly). Then Drag and drop the folder
called Music into the Music Folder of your Ipod.
STPE 5: Close all files on the Computer, safely remove the Ipod via device
Manager on Taskbar, (if using Windows).
STEP 6: Enjoy more music for less space :)....lol
how to run my ipod on mycomputer
You can easily use an iPod on a computer without iTunes. While iTunes is the program typically associated with the iPod, there are others that can work with your iPod to do whatever it is you want to do. One such program is Winamp, which can be downloaded for free online (see Resources). You can also access your iPod's files without any software at all.
Start Download
1) Click to Begin 2) Download App 3) Get 100s of Free Books & Readers
www.readingfanatic.com Step 1 Connect your iPod to your computer using a USB cord.
Step 2 Click the "Start" menu, and select "My Computer."
Step 3 Double-click the drive that contains your iPod. It typically has iPod in the drive name, such as "WILLIE'S IPOD."
Step 4 Click the "Tools" menu, and select "Folder Options," then choose the "View" tab. Click the circle next to "Show hidden files and folders," and click "Apply," then "OK." A folder called "iPod_Control" will now appear.
Step 5 Double-click the "iPod_Control" folder. You are now looking at your iPod's hard drive. From here you can click the "Music" folder, which will contain several folders with names such as "F00" and so on. These hold the music files from your iPod. You can copy and paste them onto your hard drive and open them in other music programs. If you'd like to control your iPod in another digital music player, continue on with the following step.
Step 6 Open Winamp. Your iPod will show up in the "Portables" list, which is located in the menu on the left side of the player. From here you can control your iPod just like you can in iTunes. You can sync, add, delete, rename files and more. Sponsored Links
Download Plsql
Download the 30 day trail version for PL/SQL IDE!
Nov 24, 2015 | Apple iPod classic MP3 Player
ipod nano chromatic reads error? will not turn on? Nano; 4th Gen;16Gig; When you attach the nano, to the USB port it shows up as a Mass storage unit; transfer music to I tunes and hit the sync button and the ; Mass Storage unit disappears, off of listing and after a while you get an error message. "UNKNOWN FAULT ERROR (-50)" Please help!!!!
Hi All,
try this out
  1. Disconnect the iPod from the computer and close iTunes.
  2. Highlight all of the following 10 lines of text that begin with regsvr32 and then choose Copy from the Edit menu of your web browser: regsvr32 /s softpub.dll
    regsvr32 /s wintrust.dll
    regsvr32 /s dssenh.dll
    regsvr32 /s rsaenh.dll
    regsvr32 /s gpkcsp.dll
    regsvr32 /s sccbase.dll
    regsvr32 /s slbcsp.dll
    regsvr32 /s mssip32.dll
    regsvr32 /s cryptdlg.dll
    regsvr32 /s initpki.dll
  3. Open the Notepad program by navigating to:
    Start > All Programs > Accessories > Notepad
  4. In Notepad, choose Paste from the Edit menu. Note: make sure that the text that appears in Notepad is the same as what is shown above.
  5. From the File menu, choose Save As.
  6. In the File name: field type appleipod.bat and save the file to the Desktop.
  7. Close Notepad and locate the appleipod.bat file. It should appear on the Desktop with the icon shown below: ts1539_1.jpg
  8. Double-click the file and you will see a black window appear on the screen for about a minute. Wait until the window automatically disappears and proceed to the next step.
  9. The appleipod.bat file can be deleted at this time.
  10. Open iTunes and connect the iPod.
  11. When the iPod appears in iTunes, restore the iPod and resync your content.
Jan 03, 2009 | Apple iPod nano 4th Generation
286 people viewed this tip
 Grubhead
Grubhead
