Tip & How-To about Office Equipment & Supplies
How to get your Dell 964 AIO printer to work correctly in Windows 7
Read through all the steps and get a good understanding of process before starting.
Step 1:
Perform manual Un-installation of OLD printer drivers Click Start > Devices And Printers, right-click on the Dell AIO 964 printer icon, and click on Remove This Device.
Step 2: Unplug the USB cable from the computer.
Step 3: Download the ZIP file R166225.ZIP from the Dell website here:
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R166225&formatcnt=2&libid=0&typeid=-1&dateid=-1&formatid=-1&fileid=224455
Step 4:
Extract all the files from R166225.ZIP intoa separate folder by themselves. Remember the location of the folder for later use. It would be best to create a new folder and extract the files to that folder to make it easier.
Step 5: Navigate to the directory you extracted the files to, locate SETUP.EXE, and run it. This will run the Dell Clean-Up Utility, which removes old printer drivers/files from your system.You may need to navigate to a sub-folder named "CleanUp_Utility" under the folder that you just created in order to run SETUP.EXE.
Step 6: Reboot the computer when prompted.
Step 7: Download the self-extracting file R146813.EXE here:
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R146813&formatcnt=1&libid=0&fileid=195111
Step 8:
Navigate to the file R146813.EXE, right-click the file name, click Properties, click the Compatibility Tab, and check off the following check boxes: Runthis program in compatibility mode for: (then select Windows VistaService Pack 2), and Run this program as an administrator.
Step 9:
Right-click SETUP.EXE, click Run as Administrator, and run SETUP.EXE.You might be able to get away with just running the executable withoutthis step, but I included it for redundancy and for safety's sake.
Step 10: Re-connect the USB cable to your computer when prompted by the Setup Utility. A small warning: when I did this step, Windows detected my printer and installed its own native drivers forthe printer, and a dialog box popped up attempting to print analignment page. I ignored this dialog box entirely. If this happens,you will be prompted by the Setup Utility to update the driver, which is what you want to do. Continue to run the Setup Utility as normal.
Step 11: Reboot the computer again.
Step 12:
After starting up Windows 7 and logging in, Click Start > Devices and Printers, double-click the printer icon. Click Customize your Printer, then the Ports Tab. Check off "Enable bidirectional support."
Step 13:
Verify that the printer is communicating with the operating system by printing a test page. You can go back to Customize your Printer and click Print Test Page.
Step 14:
If it still doesn't work try and reboot and try printing test page again.
Thank you and enjoy the tip.
-LeeTheDeuce
My printer is saying i should replace used toner container?
Dear User,
I am sharing with you the following objects to help you achieve your desired results,
1. Service manual of your printer to understand the problem
2. A link to step by step, with pictures to understand how it is done for a Samsung printer (will help you understand the process)
Link 1. : http://diagramasde.com/diagramas/otros/SF2025_SERVICIO.pdf
Link 2 : http://www.samsung.com/us/support/howtoguide/N0000190/12120/144599
Regards,
Sid
Nov 13, 2014 | Sharp SF-2030 - Lower Pressure Roller -...
i installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Dec 16, 2008 | Computers & Internet
frigidaire model ltf2940ee0
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Stpe 6 Also access and save or print your : OWNERS GUIDE, TECK DATA, OPERATING INSTRUCTION, INSTALLATION INSTRUCTIONS and any other guides listed that are needed.
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for viewing and printing.
Thank you and good luck.
Jul 14, 2008 | Washing Machines
cont read from file E:\util\cfgmgr32.dll.
Please re-insert you're HP printer CD for the 1215.
Power off the printer by pressing the off/on button. (Do not remove the data cable or power cable from you're printer).
When the HP CD loads, un-install the printer software. After un-install, restart you're system & remove the HP CD. Click on the link below for HP.
http://welcome.hp.com/country/us/en/welcome.html#Support
Under Step 1, click the circle next to - Download drivers and software (and firmware). (Turn on you're printer).
Under Step 2, (and to the right of, For product). Type in PCS 1215 - Click, Start Detection
Follow on screen instructions & allow HP to scan you're system.
Allow HP to install the correct updated drivers & software for you're printer.
This may take some time but it is worth it. You're printer should work as intended when everything is finished.
Good Luck!
Mike
May 10, 2008 | HP PSC 1215 All-In-One InkJet Printer
6,307 people viewed this tip
k24674
jasbo
jasbo
