Tip & How-To about Computers & Internet
How to restrict access to your applications on shared network?
APPLICATION LOCKER FOR WINDOWS 7
  • If you are usually sharing your computer with someone else, then you might want to restrict their access to your applications, files or documents.
  • Using the AppLocker tool, you have a few options to do this by blocking other users to access Executables, Windows Installers, Scripts, a specific publisher or path.
  • You can simply do this by pressing the Windows key then typing Gpedit.msc. Then go to Computer Navigation -> Windows Settings -> Security Settings -> Application Control Policies -> AppLocker. Right click on one of the options ( Executables, Installers, or Script ) and create a new rule. That should save you from a lot of headaches.
Computers & Internet Logo
My disk D says me when I try to open it do you want to format? how Ican solve this
u have to install window 7 again in ur pc , If u install window 7 than bit locker again give u option to unlock the disk using password but if u forget ur password of bit locker then it give u another option to open it, and this opition is to fill the recovery key into bit locker if u saved it and it is different to all driver ,if u also do'nt have this than there i s no method to open the hard drive without formatting it
Jan 15, 2013 | Computers & Internet
can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Windows XP Does Not Allow Inbound/Outbound Connections
some malware has restricted access to administrative tasks,
try to download SPYBOT
check your system +-20 min
Nov 26, 2008 | Dell Microsoft Windows XP Home Edition
99 people viewed this tip
David Payne
David Payne
