Tip & How-To about Kitchen Appliances - Others
How to install a new oven door on your electric range.
First you need to remove old oven door by opening it at a 10 or 15 degree angle and pull stright up on door,door should just slide off of the hinges.Then reposition the hinges as they spring back into the stove after old door becomes free,so position the hinges at aprox... 45 degree angle hold new door above hinges then proceed in sliding the new door on over the hinges,door should slide right in to place.KEEP FINGERS CLEAR!!!!!
Kitchen Appliances - Others Logo
removal of inner glass door.. how.??
Open door to about 15~20 degree angle, pull up on door and totally remove from stove. Lay face down on flat surface. Now can access all screws to separate the inner and outer panels and to replace the glass. To return to stove, use locking pliers to pull the door hinge stubs out to their 15 degree open position, slide door on and close.
If glass not broken, just can't see through, no need to remove door or glass. Use glass cooktop cleaner, apply and let soak 3 minutes, then use new single edge razor in holder to shave off the baked on grease. May have to repeat 3x then switch to glass cleaner and clean again 3x, should be quite clean and clear unless seal has failed on the double pane thermal glass and internally obscured in which case the only cure is to replace the glass... return to paragraph 1.
Sep 20, 2015 | Ovens
how do I remove my oven door from my stove it is a frigidaire about five years old
Open the door about thirty degrees towards you or a foot or so gap and pull up on it. It should just slide right off the hinges.
May 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
how to remove an oven door on a Kenmore self-cleaning oven
To remove door open to a 45 degree angle or till it opens at an angle not 90 degrees then pull the door up at that anglr off the hhinges.
Sep 14, 2009 | Kenmore Kitchen Ranges
oven door back on
My Jenn-Air oven door also comes off to clean. To remove the door you just open it slightly (to the first position) and lift the door up. To replace it just pull the hinge out about the same angle (about 15 degrees) and slide the door in place on the hinge levers and close the door.
Apr 29, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
595 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
