Tip & How-To about Computers & Internet
Failing Peripherals???
A Common problem with peripherals such as Keyboards, Printers, Mice etc. are that they require a new driver each time an operating system is released after the product was released.
For example, if you have a scanner from 1998 and you want to use it on the current operating systems such as Windows Vista / 7 you need to update the driver... But what if there is no newer driver available???
Sometimes, there is a workaround.
In Windows XP/Vista/7 there is a feature that allows you to run an application in compatibility mode. So using this nifty feature we can run the driver installation that you have for an older operating system on a newer one such as Windows Vista or Windows 7.
So, first we need to get the compatibility window open.
  • First, Right click on the Driver installation file (usually a .exe but sometimes can be a .zip or .rar)
  • Next, Find the tab that is called Compatibility
  • Now, you should see a dimmed out box saying "Run in compatibility mode for:" and then a drop-down menu.
  • Tick that box and then select the operating system the driver was originally created for. (Or one that is supported by the hardware)
  • Then to make sure things run smoothly, tick the box at the bottom of the dialog that says "Run as an Administrator", this will make sure it can access the files it needs to. (Sometimes can allow erroneous files into your system, Use with Caution and at your own risk)
  • Now, click OK/APPLY at the bottom and then run the driver installer.
This should then install it so that your current NEWER operating system can find and use it.
This is not 100% effective and not all products will allow you to do this, but it is worth a try as it may just fix your issues.
If anyone needs anymore info regarding this then please contact me via the email on my FixYa Profile.
Jack Isaacs (Scaasiboi)
Computers & Internet Logo
What is computer
A computer is a device that can be instructed to carry out an arbitrary set of arithmetic or logical operations automatically. The ability of computers to follow a sequence of operations, called a program, make computers very flexible and useful. Such computers are used as control systems for a very wide variety of industrial and consumer devices. This includes simple special purpose devices like microwave ovens and remote controls, factory devices such as industrial robots and computer assisted design, but also in general purpose devices like personal computers and mobile devicessuch as smartphones. The Internet is run on computers and it connects millions of other computers.
Since ancient times, simple manual devices like the abacus aided people in doing calculations. Early in the Industrial Revolution, some mechanical devices were built to automate long tedious tasks, such as guiding patterns for looms. More sophisticated electrical machines did specialized analog calculations in the early 20th century. The first digital electronic calculating machines were developed during World War II. The speed, power, and versatility of computers increased continuously and dramatically since then, to the point that artificial intelligence may become possible in the future.
Conventionally, a modern computer consists of at least one processing element, typically a central processing unit (CPU), and some form of memory. The processing element carries out arithmetic and logical operations, and a sequencing and control unit can change the order of operations in response to stored information. Peripheral devices include input devices (keyboards, mice, joystick, etc.), output devices (monitor screens, printers, etc.), and input/output devices that perform both functions (e.g., the 2000s-era touchscreen). Peripheral devices allow information to be retrieved from an external source and they enable the result of operations to be saved and retrieved.
Oct 28, 2016 | Computers & Internet
This is about a utility called DriverEasy and how to take the hassle out of keeping your device drivers up to date. DEVICE DRIVER BASICS A device driver is a piece of software that sits between the operating system and the hardware. It enables the Operating System (OS) to access the device using standard system calls. Drivers provide a convenient way of interfacing a variety of devices without the OS or applications requiring the details of directly communicating with the hardware in question. When you install a new device, you also install its driver. When the system boots up, it loads the installed device drivers into the kernel, making the devices they support available for use. In fact, when you plug-in a new device, Windows automatically starts the New Device Driver Wizard to guide you through the process of downloading the relevant driver. Every peripherals uses devices drivers because of flexibility they provide. This even includes motherboard components such as temperature management hardware. DRIVER PROBLEMS The driver flexibility made possible by device drivers leads to a problem. For example printers, because each make and model has its own requirements, you'll have install exactly the right driver if all the features are to work as they should. However those drivers are not only hardware-specific, but also operating system-specific. When Microsoft release a major new Windows update, your printer's manufacturer needs to create a new driver specifically for that version of Windows. Until this happens, your printer is basically useless. WHAT YOU'LL NEED DRIVEREASY Fortunately, there is now software dedicated to analyzing and maintaining your operating system's driver structure in an efficient way. This free utility finds and upgrades out-of-date device drivers. You'll find it at www.drivereasy.com.
Jul 12, 2010 | Computers & Internet
my keyboard's volume control does not function. I think it is because of the viruse that invades my computer. the other function is working properly. how can I fix it?? have an idea?
Hi mitsutezuka ,
  • There is nothing that is related to virus in this problem, the volume control keys on the key board are extra keys which are usually found to malfunction over a period of time.
  • Also these keys depends on the fact whether the keyboard requires a driver to be installed for them, which depends on the brand of keyboard and whether you received a driver cd along with the keyboard to enable that functionality etc..
  • It could also happen that your operating system is not supporting the keys due to some driver update.
  • In your case it seems that the keys are not functioning due to a circuit damage which is normal for such keyboards with extra keys, Though many people won't do that would recommend you to change or replace the keyboard with a new one because of this reason,if it's under warranty.
Hope this helps.
Hope this helps...
May 12, 2011 | Computers & Internet
peripheral buttons (refresh, home, mail, volume etc) not working
hi...
  • Check whether your accesories,are correctly fixedd or not..
  • and check the driver component,else re-install the external devices..
  • and check it ,then its not so,means change some other peripheral to your system and check it ,if it works properly means problem in your devices only...
  • open the keyboard in that check whether the inner rubber layer is fixed in correct position or moves some where,then check the wiring connection in inside the keyboard..
  • no use,means change the peripherals..
  • If it's useful for you means plz rate me the 4 Thumbs ....
Jan 06, 2011 | Dell Wireless Keyboard Optical Mouse w0147
How can I get an upgrade for my wireless mouse?
If your mouse manufacturer does not supply a driver for Vista you are pretty much out of luck for now. Vista is radically different from previous Windows operating systems and some hardware manufacturers are having a hard time adapting to it. If you have to have the mouse I would suggest you switch back to Windows XP till working drivers are released.
Feb 26, 2007 | Belkin F8E825 USB Mini Wireless Optical...
230 people viewed this tip
David Payne
David Payne
