Tip & How-To about Computers & Internet
Stuck DVD, Can't get CD/DVD out of draw?
This is a common problem, for whatever reason your disc is in the draw and you cant eject it, or get it out..Here is what to do to get the disc out.... get a straightened paper clip, thick needle, or very small diameter stiff wire.. now look on the front of the device you should find a small hole.. push the wire into this hole and push it right in and you will hear and feel a click and the draw will pop open, gently pull it right out, there is your disc.
Computers & Internet Logo
wheni put a disc in the ps3 it does not load up so i cant play on games my software version is 3.21
hi,
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
computer cant read printer
now i got to pay yall to fix the **** i cant see that
Jan 08, 2009 | Lexmark Z2300 InkJet Printer
Disc will not eject.
Common cause for a disc not to eject is the loose belt from the motor to the gear that closes or opens the disc tray. You need a repair man to open it and change the belt.
Jan 03, 2009 | Polaroid TDM-1421C TV
dvd will not eject
This used to happen periodically with my unit. I would just unplug it and then whatever was stuck would pop out.
Jul 21, 2008 | JVC DR-MV1S DVD Recorder/VCR
ps3 jammed disc
Unfortunately their is no step by step or guaranteed method to fix this. Here are a few things you could try: turning it off and on, press/hold the eject button, resetting while holding the eject button, shaking or tapping it a little while trying to eject it, holding it different ways ex. face disc opening down towards floor while gently tapping and pressing the eject button. Essentially do whatever you can to get the disc to jar loose, >but whatever you do, don't for any reason stick anything in the slot or try to open the case <Doing this will void the warranty for sure! If none of these work your last resort would be to return it for a new one (providing you still have your receipt and it's less than a year old) or take it to a costly repair guy.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
117 people viewed this tip
David Payne
David Payne
