Tip & How-To about Computers & Internet
How to speed up your computer
Hi we need to follow few steps to get the pc running is a good shape
1. First we need to release the flea power from the computer for that you need to shut the computer down completely un plug the power cable and leave it turned off, then push the power button on the tower itself for 30 seconds without connecting the power cable this step will relese the static power. turn on you pc now.
2. in the run box type in %temp% and hit enter it will open you all the temp junk files
press the control and A button on the key board once it highlights all the junk files then hit the delete key on the keyboard and make the temp folder empty
3. do the same delete everthing from the prefetch box too all you need to do is type in prefetch in the runbox.
after this clear all you cookied and temporary internet files too this will speed up your computer.
4. go to the add/remove program and remove all unwanted programs from the list.
Computers & Internet Logo
Getting error 6C10
hi juanc, i am happy to assist you
just follow these steps
1.Start with PRINTER OFF
2.Press and hold RESUME Button (small triangle shape in the circle) and click POWER button.
3.Green led should be ONWhile holding the Power button, release the Resume Button.
4.Without releasing the Power Button, click RESUME button for two times and release Both Buttons.
Click RESUME for four times then soon click POWER button, to confirm the selected action reset counter absorber.
5.Then Turn off the printer and turn on again
Hope it will work for your,Good Luck
Jan 23, 2011 | Canon PIXMA MX870 Wireless Office...
When I turn my computer on I get a black screen
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please release the flea power
to do so..turn off laptop. take battery out as well as unplug the power cord to ensure that no power source is connected to the computer.
hold and press the power button of the laptop for 5-6 seconds.
then alternatively turn on the laptop on both battery and adapter mode and see if it makes any difference.,
If the above does not help try the below
please restart the system and tap the F8 key on initial system logo.
in the advanced menu select the safe mode option.
login as an administrator
Click start...all programs...accessories...system tools...system restore...
in the window that appears, restore computer to earlier date and time and click next
select a date may be a week or 2 back when system was running fine and click next
follow the onscreen steps
the system restore should reverse any changes to the system that might have caused the issue to occour.
let me know in case issue persists so that i can help you further.
Nov 16, 2010 | Dell Dimension 4300S (Refurbished)...
on startup goes to bios update screen
hi,
this means that your internal battery on the computer ie. the one that is present on the motherboard has gone out, you will need to replace the battery,
if you are comfortable with it you can replace it on your own, for that
unplug all the cables from the back of the system tower,
press hold the power button for 15 sec to release any flea power to avoid shock
and the open the system tower, it will be a button shaped battery, you will need to replace it
here is a helpfull link
http://www.hardwaresecrets.com/article/81
Further Queries are welcome
if you think my solution was helpfull please do rate me
Feb 26, 2009 | Acer Aspireā„¢ T180 PC Desktop
donot startup
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Restart the system.
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Acer TravelMate 2300 Notebook
acre 5520 laptop
Assuming already installed vista.
Just try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer,scanner & monitor and power supply from the CPU.
Is it giving any error messages.
Try booting in to safe mode.
If it does then the issue is with something.
Do you have two video adapters.
Try boot from the dvd & run the recovery for vista.
or the system restore from the dvd.
At last run repair reinstallation using the vista dvd.
Hope it helps.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
111 people viewed this tip
David Payne
David Payne
