Tip & How-To about Audio Players & Recorders
How to play Blu-ray ISO backups on WD TV Live
To play Blu-ray ISO backups on your WD TV Live, one thing you should know is that WD TV Live can well play ISO files from a USB drive, while network shares do have problems actually.
In order to get an ISO backup, what’s your workflow? As all I know, some people use tsMuxeR to back up the Blu-ray disc, and then converted it into an ISO using Daemon Tools. Personally, I use Pavtube Blu-ray Copy to make ISO backups for my Blu-ray discs.
Within several clicks, this program can finish its task, and enables you to get an ISO image file. What you should do is just loading your BD files via "Source" option, and then choose "Image File (*.ISO)" from the pull down menu of "Target" to specify the destination folder. BTW, you’d better indicate your USB drive as the save path, or you need spend time to copy the ISO image to your USB drive repeatedly. Once the two steps finished, the backup process will begin, and then you just need wait for the resulted ISO files for your WD TV Live.
As long as copying task is completed, plug the USB into your WD TV, and connect it to your HDTV via HDMI cable, what you should do next is enjoying your BD movies on your widescreen TV leisurely.
One more thing I should mention is that some users have problems to play Blu-ray ISO files via their WD TV, but DVD ISO is working well. Not clear about the accurate reason, but another solution can be recommended. Since WD TV is able to beautifully playback HD MKV files up to Full HD 1080p, thus we just need a utility to convert BD files to HD MKV, and then everything will be OK. Because of the Blu-ray copyright issues, some discs are highly protected, we must take advantage of a powerful application to do so. In that case, the following Blu-ray ripper is suggested, it is able to remove nearly all kinds of BD protections, including BD+, AACS, and even MKB Version > 10 is supported as well.
This Blu-ray ripper allows users exporting "MKV HD Video (*.mkv)" format, and also enables users to reset audio and video parameters via clicking "Settings" button. You can set the resolution at 1920*1080 to remain 1080p quality of your Blu-ray movies, as well as keep 5.1 channel of the original surround sound. All in all, all the parameters like bit rate, codec name, frame rate, sample rate are all changeable in the following interface.
After your preferred settings for your WD TV have been set well, just click "Convert" button to start conversion. Once finished, you can watch them on your TV via WD TV with ease, and the high quality of the Blu-ray movie has never been changed at all.
Is this helpful? Hope it is.
can access to play on computer pictures on cruzer scan disk, forgot passwd help
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Jun 07, 2011 | SanDisk Computers & Internet
Enjoy/watch Blu-ray movies on HDTV via WD TV Want to find a solution to playback Blu-ray movies on your widescreen TV via WD HD Media Player? As a matter of fact, WD TV HD Media Player promises to play just about any video format you throw at it, including high definition video up to 1080p. You put the videos on any USB mass storage device, like an external hard drive or a thumb drive, and plug it into the device, WD TV HD Media Player will recognize the files on the drive and play any video, audio, or photo files it finds. However, according to the feedback provided by some users, WD TV HD Media Player does play m2ts selectively only, some are, and some are not. In purpose of solving this problem, this post will talk about how to rip Blu-ray movies to USB for playback on TV via WD TV HD Media Player. WD TV HD Media Player supported file formats: Video: MPEG1/2/4, WMV9, AVI (MPEG4, Xvid, AVC), H.264, MKV, MOV (MPEG4, H.264), Subtitle SRT (UTF-8) Audio: MP3, WMA, OGG, WAV/PCM/LPCM, AAC, FLAC, Dolby Digital, AIF/AIFF, MKA Playlist PLS, M3U, WPL Photo: JPEG, GIF, TIF/TIFF, BMP, PNG Now let?s have a look at its operation steps. Choose MKV format, how to rip Blu-ray to MKV? Step 1 Download, install and run this Blu-ray ripping software After launched it, you will see the following interface at once. There are three ways provided to import Blu-ray files, namely through clicking on "DVD Rom", "DVD Folder", and "IFO/ISO". Step 2 Load the Blu-ray disc. Click on the ?DVD Rom? button to import Blu-ray movie from the disc, or click on ?DVD Folder? button and browse to your target files. It takes a few seconds to load the whole movie, so be patient. A view log will pop up when loading process completes, you can simply click "OK" to confirm or press Ctrl+O to close it. Now all the M2TS files in file list are checked, right-click and choose "Uncheck All". What you need is the main movie---the one with longest duration. Check it and leave unwanted M2TS files unchecked. You can rename the output file by clicking on the file name in Destination File column. Right below the file list you could find "Subtitle" and "Audio" droplist, where you can set output subtitles and dubbings to the languages you like. Step 3 Click on Format bar, select ?Common Video? from the format list and in submenu you could find MKV video format. If you would like to maintain best quality, just back to the format list and move down your mouse to point at ?HD Video?, here you can find ?MKV HD Video?. Check it and hit on the small folder icon to specify an output folder. Then click ?Settings? and customize advanced audio and video parameters. For instance, you may set Video to 1920*1080p (to fit for the wide screen), 25mbps, 30fps, and Audio to AC3/AAC codec, 192kbps, 5.1 channels. Click "OK" to confirm your settings. Step 4. Start conversion. Click on the ?Convert? button and the program will rip Blu-ray movies to MKV video format for you very soon. You could set auto shutdown in progress window (it pops up once you click Convert) or leave it there and come back later (the ripper will tell you how long it takes). Enjoy the converted MKV videos! Once finished, you can get the generated files for WD TV via clicking on "Open" button with ease. Afterwards, just copy the output files to My Passport portable hard drive or other USB drive, and then connect WD TV to your TV, plug your USB drive into the player and you are ready to enjoy the movies ripped from your Blu-rays. That's all, Enjoy it!
Apr 13, 2010 | Audio Players & Recorders
cant remember password to wd external hard drive
USB Memory Drives"
Hope this helps
May 25, 2011 | Western Digital My Book Essential 1TB...
I cant burn my music onto CDs and my computer tells me i dont have a cd burning software when i should have one
you could use this burnaware its totally free if you dont like it just uninstall it also there are plenty of free burning sofware cnetdownload.com or majorgeeks
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://www.majorgeeks.com/CDBurnerXP_d4242.html
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
Active ISO Burner will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). Active@ ISO Burner software accepts command line parameters to automate ISO images burning process.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burnaware-free/3000-2646_4-10878661.html?tag=mncol;8
BurnAware Free is a full-fledged disc burning tool - fast, lightweight, feature-packed and, most importantly, 100% free. The program burns all types of CD, DVD and Blu-Ray discs containing data, digital photos, music and video. With BurnAware Free, you will be able to create bootable or multi session CDs and DVDs, high-quality audio CDs from your collection of MP3, WAV, WMA, OGG, M4A, AAC and FLAC files, burn disc images, copy discs to backup ISO images and do a whole lot more.
http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html
Multi-disc file backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup archives with powerful password protection; split archives automatically across multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original locations; integrated Audio CD ripper store your audio tracks as WMA or WAV files; new option for setting the number of copies you want to burn (available for all disc formats); discs can now be verified immediately without being ejected first (if the drive supports this feature); numerous other small improvements that make the program easier to use and more effective; burn files and folders on data CDs/DVDs/Blu-ray discs; burn Audio CDs from WAV, MP3, FLAC, WMA and Ogg Vorbis files; burn MP3-CDs from your MP3 files; burn Video DVD, Video CD (VCD) or Super Video CD (S-VCD); create and burn CD/DVD/Blu-ray disc images; burn speed and other options can all be set automatically.
http://download.cnet.com/Macrium-Reflect-Free/3000-2242_4-10845728.html
Macrium Reflect Free Edition. An award winning disk imaging solution for free. A complete disaster recovery solution for your home and office. Protect your personal documents, photos, music and e-mails. Upgrade your hard disk or try new operating systems in the safe knowledge that everything is securely saved in an easily recovered backup file. Macrium Reflect supports backup to local, network and USB drives as well as burning to all DVD formats. This version is for non-commercial home use.
http://download.cnet.com/ImgBurn/3000-2646_4-10847481.html
ImgBurn is a lightweight CD/DVD/HD-DVD/Blu-ray burning application that has several modes, each for performing a different task: Read - read a disc to an image file; Build - creates an image file from files on your computer or network (you also can write the files directly to a disc); Write - write an image file to a disc; Verify - ensure that a disc is 100% readable (you can also have ImgBurn compare it against a given image file to ensure the actual data is correct); and Discovery - used in combination with DVDInfoPro, you can check the quality of the burns your drive is producing.
Apr 19, 2011 | HP Computers & Internet
285 people viewed this tip
 Grubhead
Grubhead
