Tip & How-To about Cell Phones
What you should do when your phone screen flickers or freezes
When your phone freezes or flickers, you should:
1.) Turn off the phone.
2.) Remove the battery cover of the phone.
3.) Now you have to remove the battery.
4.) Clean the battery and the cover with a soft cloth to get rid of the dust.
5.) Wait for a few seconds (10-15 seconds).
6.) After that, re-insert the battery back in the phone.
7.) Put back the battery cover.
8.) Then, turn the phone on.
**I would recommend this to Sony Ericsson cell phones and there is no harm in tying it for other phone models as well.
Cell Phones Logo
My phone wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 05, 2012 | HTC Vivid
i dropped my fone when i opened the car door now it wont turn on.
5.Wait 10 seconds.
Step
Thanks
Aug 08, 2012 | Motorola Mobility Defy Cell Phone
insert sim nokia 2700c-2
Hi
Always switch the device off and disconnect the charger before removing the battery.
The SIM card and its contacts can be easily damaged by scratches or bending, so be
careful when handling, inserting, or removing the card.
1. Press and slide the back cover towards the bottom of the phone, and remove it (1).
2. Remove the battery (2).
3. Insert the SIM card into the holder with the contact surface facing down (3).
4. Insert the battery (4), and replace the back cover (5).
Remove the SIM card
Press the release spring (1), and slide out the SIM card (2).
Jun 25, 2011 | Nokia Classic 2700 Cell Phone
how to change battery in lg cosmos
Here is the Manual, Removing the battery is found on page 20
1. Hold the phone securely with both hands (as demonstrated).
2. Push the back cover up with your thumb until it disengages from the phone and then slide it up to remove
Turn the phone off, then slide the battery cover upward to remove it.
3. Remove the battery from the battery compartment by lifting the top of the battery using the opening at the top of the battery.
Mar 21, 2011 | Cell Phones
how do i determine the model number (s) on my phone
1. Turn your phone off.
2. Remove the battery cover on the rear of the phone.
3. Remove the battery.
4. Find and read the sticker that displays the model number.
Mar 30, 2010 | Lands Phones
608 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
