Tip & How-To about Computers & Internet
How to restart or shutdown a computer through a remote desktop connection
When you are connected to another computer by remote desktop, did you ever notice that the shutdown and restart options are not there. The computer that you remote desktop to must already be on. But if you regularly use remote desktop, at some stage you will want to restart the remote computer from where you are. For example you might install a program and you need to restart the computer to finish the installation. If this doesn't happen automatically then you can follow the steps below.
How to Reboot or Shutdown a Machine from Remote Desktop Connection using Windows XP?
  1. Open the run box by pressing the WINKEY and the letter R on the keyboard.
  2. Type the following command into the run box: shutdown -r -f
  3. Press Ok.
  4. This will restart the remote computer.
If you would like to shutdown the Windows Xp remote computer you can type: shutdown -f
When you are typing these commands in you must type it exactly right. If you miss a space or a dash it will not work.
Restart a remote computer using Windows Vista or Windows Seven.
On these newer operating systems the run box is almost obsolete. You only have to open the start menu and type these commands into the search bar at the bottom. This area acts as a run box and you can type commands into this.
Computers & Internet Logo
I went to the start button to restart my computer on windows 7, but noticed my shutdown, restart and sleep buttons were all white and I couldn't use them. How do I bring them back?
go to Control Panel\Hardware and Sound\Power Options\System Settings
select the " change sttings that are currently unavailable"
enable hibernation"
Feb 07, 2014 | Microsoft Windows 7 Home Premium 64BIT...
commad to shutdown than restart
I don't understand the problem.do you wan't the computer shutdown for 5 minutes or hours.then restart remotly or what.you have to give more information more information please.
Mar 30, 2013 | Acer Veriton 5800 PC Desktop
how do I reboot the computer?
Click on START -> Shutdown and scroll to restart option.
Mar 03, 2011 | HP Pavilion m7760n PC Desktop
can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
Computer restarts on shutdown
have you checked that acpi is enabled in the bios and also look in control panel, then power options and check the shutdown options are correct and not set at restart.
Apr 19, 2007 | Dell Dimension 8400 PC Desktop
417 people viewed this tip
David Payne
David Payne
