Tip & How-To about Computers & Internet
Here's how to create a shutdown shortcut on your desktop
Instead of going to the start menu, choosing shutdown, then waiting for the computer to shut all the programs down, you can create a shortcut on the desktop to do it quickly. You can create a shutdown, restart, or a logoff icon on your desktop which will work a lot quicker than using the usual buttons in the start menu.
1. Go to your blank desktop
2. Right click on a blank space and a menu will appear
3. Choose New from the menu
4. Then choose Shortcut
5. Where it says type the location of the item type in shutdown.exe -s
6. Then press next
7. Now enter a name for your icon. Mine is called SHUTDOWN NOW
8. Press next
9. The Shutdown shortcut will be on your desktop
Different combination you can type in when creating a shortcut to shutdown, restart, or logoff.
Shutdown.exe -s
Shutsdown your computer in 30 seconds and will close all programs and ask you to save all work.
shutdown.exe -r
Restarts your computer in 30 seconds.
shutdown.exe -l
This one will logoff your computer back to the welcome screen where you will need to login again.
shutdown.exe -s -t 1
Shutsdown your computer in one second. the -t 1 tells it how long to wait. (one second in this case) You can put -t 10 or even -t 1120.
shutdown.exe -s -t 15 -c "Goodbye you idiot"
This is my favorite code. It will shutdown in 15 seconds and have a message in the box saying "Goodbye you idiot"
The -c "bla bla bla" stands for a comment.
Notes:
* to stop the computer from shutting down type shutdown /a into the run box located in the start menu..
* -f will force everything to close immediately without asking to save anything.
Computers & Internet Logo
how i can boot by usb persario 2100
  • Log on to the Presario 2100 and click the "Start" button. Choose "Shut down" from the menu and confirm the shutdown at the next screen. Wait for the computer to shut down completely.
  • Press the "Power" button on the front of the computer. Wait until the screen goes blank, then press the "F10" key to enter the setup menu.
  • Press the right or left arrow key to highlight the "Advanced" menu. Arrow down to the "Boot Order" option.
  • Highlight "USB Devices" and press the up arrow until it is at the top of the boot order. Press the "F10" key to save the settings and exit the setup menu.
Nov 14, 2012 | Office Equipment & Supplies
slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
my laptop acer aspire5920 is not shutting down due to removal of my shutdown file from my laptop due to unknown reasons.
Hi dear,
Create Icons for Shutdown and Reboot If you find it annoying to access the Start Menu for shutting down or rebooting the computer, create a shutdown and reboot icon for the desktop.
Desktop Shutdown Icon Right click on the desktop
Click [New] [Shortcut] to open the Create Shortcut Wizard
Type [shutdown -s -t 00] without the brackets.
Click [Next] and type a descriptive name of your choosing for the shortcut
Click [Finish]
Add a bit of class to the shortcut by assigning it a custom icon. Right click the shortcut, click [Properties] and select the [Shortcut] tab. Click [Change Icon] and select from the icons that are displayed.
Desktop Reboot Icon Right click on the desktop
Type [shutdown -r -t 00] without the brackets.
Click [Finish]
A Final Note: If you happen to be as fanatical as I am about having nothing on the desktop, drag the new icons into the Quick Launch area of the Taskbar.
then use it.
if not resolve it
then use following step ;-
click on start then go to RUN and type SFC /SCANNOW
press enter
this command recover all windows lost files, if it will ask windows CD then enter the windows disk.
bye take care
good luck
veeru
May 07, 2009 | Acer Aspire 5920 Notebook PC
HP dv6835tx Notebook with Visa Ultimate 64-bit will not shut down
From what you've described, it sounds like you are clicking the Standby button, instead of the actual shutdown option. On the Start button, you will see (from left to right); Left: Start Search Middle: Standby Middle: Lock Right: Arrow Clicking the arrow will show you the Shutdown menu option; http://blogs.chron.com/techblog/archives/shutdown.jpg
May 26, 2008 | Computers & Internet
161 people viewed this tip
David Payne
David Payne
