Tip & How-To about Computers & Internet
Rotating Text in Cells
In Excel, text of cells can be rotated to any direction or to a certain angle. It is called the orientation of the text. By default, orientation of text is horizontal.
To change the orientation of text, follow these steps.
  • Select cell or range of cells that contains data you want to rotate.
  • Select ”Cells” command from “Format” menu OR Press Ctrl+1, Format Cells dialog box appears.
  • Click Alignment tab of dialog box.
  • Specify angle in ”Degrees” spin box of orientation section.
  • Click “OK” button of dialog box.
Computers & Internet Logo
how to rotate the screen on a gateway touch screen desktop
Hi. I am fairly certain you would need to go into the Windows Control Panel. Go to "Display, then "Adjust Screen Resolution." Where it says "Orientation," change "Portrait" to "Landscape." This is generally how you change the screen orientation in Windows for most PC's. I hope this has helped you. Thanks!
Oct 18, 2014 | Gateway Computers & Internet
sideway screen INSPIRON mini how do I fix it
Changing the screen orientation of your Windows display can make your screen rotate at a 90-degree, 180-degree and 270-degree angle. By default, Windows operating systems do not come with a built-in mechanism to change the screen's orientation. Certain graphics boards, such as Intel, utilize hot keys to change the screen orientation. If the hot keys do not work on your computer, a program can be installed to create shortcuts that change the screen's orientation. One such program that is Windows compatible is called "iRotate," which is available to download for free.
Turn your computer on and wait for it to load. Once your computer finishes loading, make sure any open programs are minimized or closed. Press and hold the "Ctrl" and "Alt" keys on your keyboard. Press the corresponding arrow key on your keyboard for the direction to which you want to orient your screen. Press and hold the "Ctrl," "Alt" and up directional arrow key to return the screen to its regular orientation. iRotate Application Open the iRotate download site (see Bottom of page.) in your web browser. Click on the blue download link on the left-hand side of the page. The download link contains the text "iRotate" and has an icon of a floppy disc. Save the file to your computer. Open the iRotate file and follow the on-screen prompts to install the program to your computer. You can choose whether or not to put a shortcut on your desktop, place a folder for the program in your "Start" menu or automatically run the program after it finishes installing itself. Right-click on the iRotate icon in your taskbar. The iRotate icon is a blue rectangle that will display information about your graphic properties when you hover your mouse over the icon. Select a screen orientation from the drop-down menu. You can choose a 90-degree, 180-degree or 270-degree rotation. The "Normal Landscape" option returns your screen to its default orientation. iRotate
http://www.entechtaiwan.com/util/irotate.shtm
Mar 01, 2013 | Dell Inspiron Mini 10 Notebook
Cant get phone to turn sideways for texting, internet or pictures.
Check under your settings to see if you have the screen orientation option turned off.
-go to Settings > Sound and Display > Orientation
-Orientation should be checked if you want to be able to rotate the screen
Good luck.
Jun 07, 2010 | HTC Hero Smartphone
excel formula help
formula for the keys or short curt for excel
Jul 15, 2008 | Microsoft Excel for PC
FORMULA FOR TEXT FORMATING
Yes of course, if you have a little background of visual basic programming that's possible you can enhance your requirements.
Please see link http://www.techonthenet.com/excel/questions/cond_format1.php
Nov 29, 2007 | Microsoft Excel for PC
122 people viewed this tip
David Payne
David Payne
