Tip & How-To about Computers & Internet
The Five ways to make your keyboard easier to use
5 ways to make your keyboard
easier to use For most people, the keyboard is the main way to enter information into and control their computer. But are you controlling your keyboard, or is your keyboard controlling you?
If you make typing mistakes or find your keyboard a bit uncomfortable, it’s not hard to correct those problems. Here’s how to quickly and easily change your keyboard settings and comfort options.
1. Get to know your keyboardEven if you’ve been using a PC for a long time, there may be features on your keyboard you don’t know about. Take a moment to get to know your keyboard so you can be more efficient when you're working.
2. Change keyboard settingsOnce you’ve gotten more familiar with your keyboard, there are a few settings you can change to help you work more smoothly.
You can alter:
  • How long you need to press a key before the keyboard character starts repeating.
  • The speed at which keyboard characters repeat, which helps you to avoid typing errors.
  • The rate at which the mouse pointer blinks, which can help its visibility.
Here's how to change keyboard settings in Windows Vista or in Windows XP .
3. Take shortcuts Even if you're a whiz with the mouse for Windows 7, Windows Vista or Windows XP, keyboard shortcuts are typically a more efficient way to work. They're called shortcuts because they reduce multiple clicks into one quick press of keys, like hitting a chord on a piano.
Getting to know a few keyboard shortcuts for the things you do all the time, like saving or closing files, can make using your PC much easier and faster.
Here are just a few popular keyboard shortcuts that work for both versions of Windows:
Press this
To do this
Windows logo key Open the Start menu
ALT+TAB
Switch between open programs or windows
CTRL+S
Save the current file or document (works in most programs)
CTRL+C
Copy the selected item
CTRL+Z
Undo an action
Windows logo key +F1
Display Windows Help and Support
ESC
Cancel the current task
Application key Open a menu of commands related to a selection in a program. Equivalent to right-clicking the selection.
For more, see the detailed list of keyboard shortcuts for Windows Vista, or Windows XP. Note: shortcuts for Windows 7 are the same as those listed for Windows Vista.
4. Make it easier to press multiple keysDo you find it difficult to press multiple keys at once? For example, if pressing CTRL+ALT+DEL is an acrobatic feat, you can set up Sticky Keys. With Sticky Keys you can hit one key at a time in a keyboard shortcut. You can even set it to make a noise so you know it's working.
You can set up Sticky Keys in Windows 7, Windows Vista or Windows XP. (Hint: Press your “SHIFT” key 5 times in a row, then click on the link, to get going with Sticky Keys in Windows 7 or Windows Vista.)
5. Find a comfortable keyboardIt might also be time for you to evaluate the ergonomics of your desktop. Microsoft offers a full line of Natural and Comfort Curve ergonomic keyboards to ensure you're comfortable when you're working on your computer. Having the right keyboard can really make a difference!
Tips for using your keyboard properly
If a new keyboard isn’t in your future, be sure to use your current keyboard properly to avoid soreness or injury to your wrists, hands, and arms. This is particularly important if you use your computer for long periods of time.
Curious about how to create a more ergonomic work space for yourself? Check out these tips to help you work more comfortably and reduce your risk of painful injuries or disorders.
Here are some general tips to help you avoid problems:
  • Place your keyboard at elbow level, with your upper arms relaxed at your sides.
  • Center your keyboard in front of you. If your keyboard has a numeric keypad, you can use the spacebar as the centering point.
  • While typing, use a light touch and keep your wrists straight.
  • When you're not typing, relax your arms and hands.
  • Take short breaks every 15 to 20 minutes.
  • Type with your hands and wrists floating above the keyboard, so that you can use your whole arm to reach for distant keys instead of stretching your fingers.
  • Avoid resting your palms or wrists on any type of surface while typing. If your keyboard has a palm rest, use it only during breaks from typing.
Computers & Internet Logo
System control buttons not working on Toshiba Satellite a660
You can adjust these settings on the Make the keyboard easier to use page in the Ease of Access Center. 1. Open the Make the keyboard easier to use page by clicking the Start button , clicking Control Panel, clicking Ease of Access, clicking Ease of Access Center, and then clicking Make the keyboard easier to use. 2. Select the options that you want to use: • Turn on Mouse Keys. This option sets Mouse Keys to run when you log on to Windows. Instead of using the mouse, you can use the arrow keys on your keyboard or the numeric keypad to move the pointer. • Turn on Sticky Keys. This option sets Sticky Keys to run when you log on to Windows. Instead of having to press three keys at once (such as when you must press the CTRL, ALT, and DELETE keys together to log on to Windows), you can use one key by turning on Sticky Keys and adjusting the settings. This way, you can press a modifier key and have it remain active until another key is pressed. • Turn on Toggle Keys. This option sets Toggle Keys to run when you log on to Windows. Toggle Keys can play an alert each time you press the CAPS LOCK, NUM LOCK, or SCROLL LOCK keys. These alerts can help prevent the frustration of inadvertently pressing a key and not realizing it. • Turn on Filter Keys. This option sets Filter Keys to run when you log on to Windows. You can set Windows to ignore keystrokes that occur in rapid succession, or keystrokes that are held down for several seconds unintentionally. • Underline keyboard shortcuts and access keys. This option makes keyboard access in dialog boxes easier by highlighting access keys for the controls in them. If that does not work you may need to visit the web site of your computer manufacturer to see if they have some specific software installed on your computer that controls key functions.
Aug 31, 2011 | Computers & Internet
The keyboard is recognised by the computer and more or less functions as it should, however various keys do not seem to function, for example the enter key and backspace key have no effect when pressed. Any ideas what might be wrong?
The 'Enter' and 'Backspace' are two of the most essential keys on a keyboard. It is highly unlikely that they would fail due to a software or driver problem.
It really sounds like the keyboard is actually defective.
I suggest you try plugging it in to another computer. If the same keys are failing the keyboard is defective.
Hope this helps.
Jul 04, 2011 | Microsoft Wired Keyboard 600
My mouse is NOT working but the keyboard is....HELP I can not access the online manual because the mouse doesn't work and I don't know how to manually work the keyboard......
Here is a list of shortcuts for IE. Here is a list of key board shortcuts for windows.
You could use mouse keys by configuring the key board. How to configure mouse keys: Here. In Vista (you haven't specified your OS) Keyboard actions 1 To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
To open the Ease of Access Center, press:
  • Windows logo key winkey.gif+U.
2 Under Explore all settings, select:
  • Make the mouse easier to use.
  • Make the mouse easier to use by pressing TAB, then ENTER.
3 Under Control the mouse with the keyboard, select:
  • Turn on Mouse Keys by pressing ALT+M.
This has two or may be 3 posts following this since its too long
Jun 04, 2010 | Microsoft Wireless Optical Desktop Comfort...
149 people viewed this tip
David Payne
David Payne
