Tip & How-To about Computers & Internet
How to Set up a Linksys router for Cable Internet
This tip will give you a step by step instruction on how to manually setup or install a Linksys router for Cable internet.
This guide is recommended for Cable Internet Service in the USA like Charter, Cox, Comcast, Cable Vision, etc.
  1. First you need to connect the device together. You need to connect your cable modem to the internet port on the back of the router, and the computer should go to one of the 4-port on the router labeled Ethernet (1, 2, 3,4).
  2. Then turn on the modem first, wait for the lights to stabilize before powering on the Linksys router. Lights that you should have on the router are Power (solid green), Wireless/WLAN (Green sometimes flashing), One of the no. lights where the computer is plugged in (flashing), And the internet light (flashing).
After doing this step there are times that this will already get you online.If the internet will not work, you continue following the steps 3.
3.If the internet is still not working; we will need to adjust a setting on the router setup page. To access the setup page of the router you need to open your internet explorer or Firefox on the computer that is hardwired directly to the router. In the address bar of your browser(Internet Explorer or Firefox) type http://192.168.1.1/and hit enter or click Go. It will ask you for a username and password.Just type "admin" for the password field and there is no username. Ifyou have ran the setup CD prior to this, then use the password that you have set when were running the setup CD.
4. Once you are in the setup page of your router make sure that the Internet Connection Type is set to Automatic Configuration DHCP, then click the save the settings button at the bottom of the page. After saving the settings, click the sub tab at the very top of the page that says MAC Address Clone. Set it to enable and click the button that will say Clone or Clone your PC's MAC and save the settings again.
5.After doing step 4, do a power cycle. Power cycle is done by turning of the router, modem and computer. Leave them off for a minute, tuned them back on in this order. Modem first wait for the lights to stabilize,then the router wait until the power light become solid. Then turn on the computer. This will get you online through the router.
Computers & Internet Logo
hi ya i have the problem tht i cant configure my router how to enter into it and give my password
print2.gif print email2.gif email
Title: Setting up your Linksys Router for the first time Article ID: 21463
Your Linksys Wireless-N Router comes with the Cisco Connect software which makes setting up and managing your Linksys Wireless-N Router a quick and simple experience. You'll have your Linksys Wireless-N Router up and running in no time.
NOTE: The Linksys E2100L router is only available in the U.S. For help on setting up a Valet or Valet Plus, please click here.
Some basic requirements before you begin
i. An active Internet connection.
ii. A computer with a wireless or wired Ethernet adapter, running one of the operating systems below.
- Windows XP with Service Pack 3
- Windows Vista with Service Pack 1 or better
- Windows 7
- Mac OS X Tiger 10.4.9
- Mac OS X Tiger 10.4.11
- Mac OS X Leopard 10.5.8
- Mac OS X Snow Leopard 10.6.1
Getting started
Provided that the above requirements are met, you can now begin setting up your Linksys Wireless-N Router. In this example, we'll be setting up the Linksys E3000 High Performance Wireless-N Router. The following steps will walk you through the entire process.
Step 1:
Your Linksys Wireless-N Router allows you the freedom of running setup via a wired or wireless connection. Therefore, please start by performing the instructions under the description that best matches the computer you're working with. Proceed to Step 2 once you're done.
Description A:
You are using a computer with no wireless connectivity that is normally connected with an Ethernet cable to your DSL/Cable modem.
Instructions A:
Please connect one end of the supplied Ethernet cable into the Ethernet port on your computer, and connect the other end into one of the numbered Ethernet ports at the back of your Linksys Wireless-N Router.
Description B:
You are using a laptop with a built-in wireless adapter.
Instructions B:
If you're using a laptop, please ensure that its wireless feature is switched ON, and that your laptop is positioned within 5 feet of your Linksys Wireless-N Router.
NOTE: Most laptops have a switch that turns its wireless feature ON and OFF. Refer to your laptop's documentation or online help if you're unsure where this switch is. This doesn't apply if you purchased an external wireless adapter separately.
Step 2:
On your computer, insert the supplied Setup CD that came with your Router. Setup should start automatically.
NOTE: If setup doesn't load automatically, please click here.
Step 3:
The first screen greets you with the Software End User License Agreement. Please take a moment to read through and understand the agreement. Once you're ready, go ahead and click Next.
NOTE: The Linksys Wireless-N Router model displayed on the setup screen may vary based on the Linksys Wireless-N Router model you have.
Step 4:
On the next window, please follow the on-screen instructions on how to connect your Linksys Wireless-N Router:
kb21463-002_en.png Plug one end of the power cable into your router and the other end into an electrical outlet.
NOTE: The Linksys E3000 features a power switch, located at the back-end of the unit, next to the power port. Please make sure that this switch is ON. Other Router models may not have this feature.
kb21463-004_en.png Plug the Internet cable into the yellow port in the back of your router labeled "Internet". Plug the other end into the modem.
QUICK TIP: Click Show me how for an illustrated guide on how to complete the above instructions.
After completing the above steps, click Next to continue.
Step 5:
Setup will now perform a series of tests to determine the optimum configurations for your network. You may notice your computer connecting and disconnecting to a wireless network several times. This is normal. Your wireless network is simply being secured.
NOTE: The setup process automatically generates a unique and secure Wireless Network Name (SSID) for your convenience.
kb21463-006_en.png Step 6:
The next part of the setup automatically detects your Internet connection type. If you are using a DSL connection, you may be requested to enter your account details. If this is the case, simply enter your Account name and Password in the allocated fields. Otherwise, you may skip ahead to Step 7.
NOTE: If you don't know your Account name and Password, your Internet Service Provider (ISP) will be able to provide these details.
QUICK TIP: Click Examples to see what your Account name should look like.
kb21463-007_en.png NOTE: Cable Internet users will not see the above screen.
Step 7:
Sit back and wait a moment as setup finalizes your Linksys Wireless-N Router settings, and re-establishes your Internet connection.
kb21463-008_en.png Step 8:
Once your Internet connection is up and running, a confirmation window similar to the screenshot below will appear on your screen. Your Linksys Wireless-N Router is now secure and connected to the Internet. This concludes the setup process. Click OK to continue.
Step 9:
You will now be taken to the main Cisco Connect window which lets you manage and further personalize your network settings. If you would like to learn more about the available features in Cisco Connect, please click here. Otherwise, you may click on the Close button to exit Cisco Connect, and begin surfing the Internet right away.
NOTE: To launch Cisco Connect again at later time, on a Windows computer, go to Start>All Programs>Cisco Connect. To launch Cisco Connect on a Mac computer, navigate to the Applications folder in Go, and then start Cisco Connect. For more help on this, please click here.
kb21463-010_en.png NOTE: Cisco Connect is automatically installed each time you use the Setup CD or Easy Setup Key to setup or connect to your Linksys Wireless-N Router.
© 2010 Cisco Systems, Inc. All rights reserved.
Nov 04, 2010 | Linksys Wireless-G WRTP54G Router
linksys will not connect correctly to my laptop
Try a new setup.
Step 4:
Step 5:
Step 7:
Step 9:
Nov 02, 2010 | Linksys Wireless-G WRT54G Router
how to configure my router to ADSL2 modem router
- Windows 7
Getting started
Step 1:
Description A:
Instructions A:
Description B:
Instructions B:
Step 2:
Step 3:
Step 4:
Step 5:
Step 7:
Step 9:
Oct 16, 2010 | Linksys Wireless-G WRT54G Router
how do i configure my cable modem to a linksys router
On this hub this will give you a step by step instruction on how to manually setup or install a Linksys router for Cable internet.
  1. First you need to connect the device together. You need to connect your cable modem to the internet port on the back of the router, and the computer should go to one of the 4-port on the router labeled Ethernet (1, 2, 3, 4).
After doing this step there are times that this will already get you online. If the internet will not work, you continue following the steps 3.
3. If the internet is still not working; we will need to adjust a setting on the router setup page. To access the setup page of the router you need to open your internet explorer or Firefox on the computer that is hardwired directly to the router. In the address bar of your browser (Internet Explorer or Firefox) type http://192.168.1.1/ and hit enter or click Go. It will ask you for a username and password. Just type "admin" for the password field and there is no username. If you have ran the setup CD prior to this, then use the password that you have set when were running the setup CD.
5. After doing step 4, do a power cycle. Power cycle is done by turning of the router, modem and computer. Leave them off for a minute, tuned them back on in this order. Modem first wait for the lights to stabilize, then the router wait until the power light become solid. Then turn on the computer. This will get you online through the router.
I hope this one helps. Don't forget to share or rate this.
Thanks for reading and dropping by.
Step by Step Guide to setup cable modem to a linksys router With Graphic/ pictures
Click here
Please rate my solution
Apr 02, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
405 people viewed this tip
David Payne
David Payne
