Tip & How-To about Computers & Internet
How to change a drive letter
Sometimes it is necessary to change the drive letter of a hard drive or other drive connected to a computer.
To do this , Select start and go to “Control Panel”
No open “Administrative Tools “ and select “Computer Management”
Then select “Storage” and finally select “Disc Management”.
This should bring up the following screen :
The graphs each represent a drive or partition connected to your computer. In the graph , additional information is displayed about the drive including it’s Format , Size , Label and Drive Letter.
To change a drive’s letter , right click on the graph of the drive you wish to change and select “Change drive and letter paths”.
On the dialog , select “change” and this will now bring up the following screen :
From the drop down menu , select the drive letter you wish to assign to the drive and select OK. Only letters that are available are displayed , so if you need to assign a letter that is not visible in the list , you will need to re-assign the drive with that letter to a new letter first.
You may get a error dialog warning you that some programs depend on the drive letter. If no programs are installed on the drive , this should not be a problem. If you have trouble with programs that do not work after you have set the drive letter , simply change it back to the original letter or reinstall the affected program.
Please remember to rate this tip if you found it to be helpful.
Kind Regards
StephanSA
Computers & Internet Logo
Having a problem with an external HDD. Although it is getting power - any OS cannot seem to pick up the HDD. This means I cannot access any of my files. It is a Samsung G2 Portable HDD.
Sometimes it takes a few minutes for the computer to detect a USB device when it's plugged in. Try rebooting the computer while the external hard drive is connected and powered. Then wait a few minutes before we start worrying. The last resort is to contact Samsung and tell them their product is defective - they might have a fix.
Dec 30, 2010 | Samsung Computers & Internet
I can't access my iomega 1TB desktop hard drive, it tells me to insert a removable disk when ever i click on it from My Computer
Hi.
Test the IOmega using a different computer. If it does the same the SATA connector to the hard drive, inside the closure may have slipped off.
If problem is computer, power off and disconnect power cord for ten minutes. If the computer is a laptop also remove main battery.
Disconnect hard disk, and connect everuthing back.
This will fix some USB related problem.
If that does not fi the problem, a system restore to a date before problem started may help.
Jun 13, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
hard drive needs to show as f instead of g on computer when plugged into usb
Connect your harddrive to computer then when you power up the computer press F8 key then enter in safe mode.
Then it fix messup .
If still not show as G then right click on my computer icon then click on manage.
Then click on storage->removable storage or disk management there you can see your drive icon right click on it then change drive letter.
Nov 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Windows XP is no longer recognizing my cruzer 8gb
With the flash drive plugged into your computer, go to start>settings>control panel>administrative tools>computer management>disk management
Your flash drive should be there. Right click it and select "change drive letter and paths." Click on "change." Change the drive letter.
Just follow the directions to finish.
Sometimes, if you turn the computer on, insert the flash drive, and reboot, the drive will show up, it is detected on start along with your other drives.
(I recommend starting at the end of the alphabet (Z) and work backwards when selecting the drive letters for flash drives, that way, in the future it will be easier to recognize them.)
Jan 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
256 people viewed this tip
David Payne
David Payne
