Tip & How-To about Toshiba Satellite A105 Notebook
Upgrading Toshiba Satellite A105 to Windows 7
Before you do anything I strongly recommend you upgrade the RAM to 2GB. Your system can only support 2 GB of DDR2 PC2-5300 with a maximum of 1 GB per slot. Windows 7 will work OK with 1 GB, but more is better! One memory stick can be found under the keyboard, which can be accessed by popping the top plastic strip right in front of the monitor, unscrewing the two retaining screws, and lifting the protective film over the memory. The second module is on the bottom of the system . You unscrew the memory compartment, which is located directly below the battery and to the right of the Toshiba model sticker.
The rest of this Review is pretty much for any system. I will be providing more How-Tos specific to certain laptops soon.
Next, I suggest you clean install Windows 7 on your system. Even when clean installing, Windows 7 can preserve your entire original installation in a Windows. old file in the root of C:. This means you will be able to retrieve all of your documents and everything else, even run old programs from this folder temporarily. However, I would suggest migrating your files from windows.old to their corresponding folder in Windows 7.
Windows 7 has a massive preloaded driver database, so most of your hardware should be installed immediately. If there are drivers missing, and even if everything is covered, you should run Windows Update immediately to ensure you have the most current version of Windows 7 and all hardware drivers.
Finally, you need to the "Toshiba Software Installer for Windows 7" . This will install the "Hot key functions" and additional drivers for the notebook that is not detected by Windows 7.
Go to the link below:
Enjoy Windows 7!
Toshiba Satellite A105 Notebook Logo
Can the LG Xnote RD405 laptop intially with 1gb RAM be upgraded to 4 gb using two 2gb RAM's ? Please help me by providing an answer clearly, Thanks in Advance.
Here is the memory specifications from LG.
Maximum Size: Each slot is 1024MB and can be expanded to 2048MB.
SO DIMM Type for Memory Expansion: DDR2 SDRAM SO-DIMM (256MB, 512MB, 1024MB)
It can take a maximum of 2 gigabytes of ram. It will take two 1 gb sticks. It uses DDR2 laptop ram. You need to check to see if you have one stick that has 1 gb or 2 sticks that have 512 mb each. That will tell you if you need to buy one or two sticks of ram at 1 gb each. You will be able to tell a difference going from one gb to two gb of ram. I think it would be worth the investment if you plan on using the computer for another year or more.
Oct 05, 2015 | LG Computers & Internet
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
how much maximum ram does acer aspire 4520 support? and is it fine if we have one ram of 2 gb and the other of 1 gb?
Your machine currently has this ram (1GB DDR2 667 SDRAM)
You can upgrade to 4GB DDR2 800MHz ram, sell old one off.
If you use old ram you must exactly match to old in speed, ie 2GB ddr2 667 SDRAM.
I recommend renew with matched larger faster ram 2 + 2 GB DDR800
Dec 18, 2009 | Acer Aspire 4520-5141 Notebook
My Acer Lap-top Aspire 5570Z with 80GB HDD & 512 MB DDR2 is very very slow. Can its DDR2 be upgraded to 2 GB.
what the max ram is for this laptop? I bought 2x2GB dual channel ram for it and windows vista home premium (32bit) only recognizes upto 2GB, but CPU-Z recognizes more than that.
Mar 17, 2009 | Acer Computers & Internet
DDR2 RAM for P5RD1-VM
The ASUS P5RD1-VM takes the PC2700/3200 DDR SDRAM DIMMs. You can upgrade your ASUS P5RD1-VM to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory. For best system performance use the maximum amount of allowed Memory per slot for your system i.e. 1 GB.
Thanks
Iqbal
Apr 14, 2008 | ASUS P5RD1-VM Motherboard
6,812 people viewed this tip
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
