Tip & How-To about Video Game Consoles & Games
Nintendo dsi
Hi if you have a problem with the L and R buttons I have a solution:if you do have a problem with the L and R buttons all you have to do is blow in the spaces and keep pressing the buttons until they work.
I hope this tip helped you because it really helped me.
Video Game Consoles & Games Logo
Why horn keeps blowing on 1986 porsche 911?
hi there
The horn is blowing while you turn your steering wheel ,correct?
when you took of the horn button it was still blowing?Do you have an alarm from factory on the car?
ivan
proporsche@yahoo.com
Sep 09, 2014 | 1986 Porsche 911
1996 chevy 1500 z71. Keeps blowing fuse when trying to use push button 4 wheel drive. Note: 4- Low and 4-Hi stay lit and blinking before fuse blows. New actuator. New switch on transfer case. New transfer case motor. New push button.
Cheak all wiring, one little **** in the wire will make a fuse blow. I had the same problem with my starter and i replaced the starter but it was still blowing the fuse, come to find out it wus a wire burnt into so cheak all wires carfully.
Nov 09, 2010 | 1996 Chevrolet K1500
Four Wheel drive not working. Blows fuses.
Hi:
Your four wheel drive push button system has only 3 components, so there is a way to narrow down what is blowing the fuse:
the system includes the push button panel and indicator light, the shift control module, and the shift control motor.
The shift control motor is the only part that can draw enough current to blow the fuse. If for some reason the transfer case is jambed up, that could blow the fuse too...So if you are planning on attempting repair yourself:
first, unplug the connector off of the shift control motor, and see if the fuse still blows.. if not, then remove the shift control motor from the side of the transfer case and plug it back in to the harness and see if the fuse blows. If so, then the shift control motor is bad, if the fuse doesnt blow then you need to check out your transfer case.
Dec 08, 2009 | 2000 Chevrolet Blazer
'88 Camry AC buttons not working
fan speed controler could be bad, fan motor rellay could be bad.
Apr 14, 2009 | 1988 Cadillac Sedan DeVille
211 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
