Tip & How-To about Computers & Internet
Samsung 214T No picture or wavy picture repair
The Samsung 214T has a known issue with the backlight power supply going out. The dark screen with green power light, slow to display picture or power light blinking are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide with pictures posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply, model NP-20. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $30 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Computers & Internet Logo
monitor is blank but green lightis on L1975NW
LCD Display/ control board Defective, send to repair
Dec 28, 2009 | Westinghouse L1975NW Monitor
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
3 year old Samsung 214T Monitor not workihg
Seems to be a problem with power supply or the Invertor board.You need to open it to be able to fix it.
Samir
Jan 03, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SyncMaster 214T 21.3 conductors
Leaking capacitors on power supply in monitor atleast replace the 2 820u & 1 330u 25v
Look for electrolite ozzing out
Aug 25, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
2,405 people viewed this tip
David Payne
David Payne
