Tip & How-To about Audio Players & Recorders
Home Theater Setup - Rear Speakers
When people install their own home theater systems they typically use these small stick-type stands for the rear speakers. This leaves one (or all) rear speaker blasting right into your ear, which is not how the rear speakers should be.
Rear speakers should be mounted two to three feet above ear level or higher, get those speakers off of the stands and onto the walls. The reason for this is that they were intended to add a background effect, they are not meant to distract your from the picture.
If your room (or significant other) does not allow speakers to be mounted up, then move your rears back a bit and aim them towards each other, this will maximize their effect and not distract you from the front while you enjoy your movie.
Lengthen speaker cable
i had same problem. yeah, there's not much wire included. i just purchased a spool of speaker wire and got the length i needed. since the wires are usually color-coded, i tagged each new wire with 2 stick-on-spots, with sticky side back to back over the wire, and wrote RR & LR to make it easier for locating them in a jumble. you can also just splice and tape extra wire on but i feel every cut cuts back on quality of sound.
May 27, 2009 | Montgomery Ward Audiovox DV1201 Theater...
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
180 people viewed this tip
 Grubhead
Grubhead
