Tip & How-To about Audio Players & Recorders
How Loud Can it Go?
I don't know if I ever installed a sound system to any concert fan who didn't ask me this question. So how loud can I safely play my sound system?
If you have a receiver or amplifier that has an analog dial that goes from 7 o'clock to 5 o'clock the majority of units will output maximum volume at around 1 o'clock assuming a line level signal is sent to it (again it varies a lot from piece to piece). Anything higher then that and the unit will send out a distorted signal colloquially referred to as "clipping". Most modern units now use digital volume controls and everyone is different. The only way to detect this distortion is listen to when the music sounds tinny and harsh instead of clean and musical.
If you do not find it is loud enough for your liking you must invest in a more powerful amplifier or higher efficiency speakers; or you will continue to destroy your innocent speakers and blame them for your over driven amplifier.
2003 Nissan Xterra - Fan noise when a/c on
No that doesn't sound like the problem, the fan clutch locks up to cool the engine off due to the increased load of the AC system on the cooling system, so it locks up and gets much louder. If it didn't lock up the engine would overheat.
Jun 28, 2012 | Cars & Trucks
what is the administrator password of acer aspire 5738Z?
There is no default password for Administrator user.
Normally you can set the Administrator during installation. If you don't know or you didn't install the system yourself ask who install the windows for the password.
Aug 24, 2011 | Acer Aspire 5738Z-423G32Mn Notebook
AVR SR6004 switches off while BD player is playing. What do I do?
There are two circumstances that I know of that a properly installed unit such as your Marantz would shut down. So here is the Theory and Data I know of.
A Your receiver has a great deal of amplification power. If it is in a closed cabinet without excellent ventilation, it will shut down if used at high volumes because because over heating. Because of it's very high power, when played loudly, it generates excessive heat.
When watching certain movies the BD player may be over-driving the limits of the amplifier section of your receiver. Page 78 of your owner's manual addresses this. Here is a link to download the manual from Marantz.
http://us.marantz.com/us/Support/Pages/Manuals.aspx
B There is one other very important thing I should mention to you. When people use high powered equipment and initially turn up the sound. After a short time, the mind turns it down. What next happens is the reason professional musicians and sound engineers often have permanent hearing loss after a relatively short time.
What tends to happen is that the listener and often the engineer running the sound mixing board at a concert(after a certain period of time) believes the sound is not loud enough when it really IS loud enough. (this tricks the audience as well) and engineer turns it up. After turning it up, his mind (and the audiences') turns it down mentally and they again think and agree that it not loud enough and then again, the volume level is turned up. And up. And up. The only reason I'm not deaf is that I discovered this when I was building sound systems as a kid. I also studied about it. So please be careful when you play things loud. Permanent hearing loss starts to occur at the very high frequencies and rolls down from there over a period of time. Hearing loss can start to occur in just a few hours at 110 decibels. permenant hearing loss is exactly just that. Permenant! It just doesn't come back. If you use this information, you will enjoy hearing music for the rest of your life.
I hope this helps,
Best Regards,
Mark
Jan 22, 2011 | Marantz Audio Players & Recorders
s8300 bad audi
since ur rock concerts music was too loud ur cell's frequency cld not capture it as it was... if u wanna record audios then try keepin it away frm the speakers.. then it wld b fyn
Apr 10, 2010 | Samsung S8300 Ultra Touch platinium-red...
cpu makes noise when play game
blown any dust out of the back of the pc?
hope i was helpfull
good luck
Mar 18, 2009 | HP Compaq d530 SFF PC Desktop
195 people viewed this tip
 Grubhead
Grubhead
