Tip & How-To about Televison & Video
Are lamps easy to install!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Are lamps easy to install?
I think it is! And also it depends on what brand is your TV I have told people how to change it and they do its not hard.
And There are really good videos that show you how to I will add some links so you can see.
You just need: Standard Philips or Flathead screwdrivers, Pair of Pliers, a new lamp
Televison & Video Logo
I recently replaced my lamp light on my 50HM66 the tv worked great for about a week then while watching tv my screen went black and lost sound. When I turn on my tv it begins to shut off and on numerous times I also have unplugged the set for about 30 mins. Is my tv shot or is this a possible easy fix?
Hey it sounds like you may have one of two problems here one you may have a bad lamp issue or two a bad ballast board I think at this point it will be a ballast it might be to weak to turn on the lamp or it is burning out the lamps to soon here is a link about Toshiba will change the way you think about this BRAND
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
PLEASE RATE THIS AS I DO THIS FOR FREE !!!!
Oct 04, 2010 | Toshiba 50HM66 52" Television
after replacing tv lamp cartrige for my tv Mitsubishi WD-52725, the timer green light keep flasing and tv would not turn on,
Please check the installation, the lamp door is not placed correctly or still open. this is causing the door micro switch to stay open. take out every thing and put it back exactly the wat it was before you changed the lamp. it is slso easy to by pass this switch if required.
Mar 08, 2010 | Televison & Video
my TV is getting dimmer and dimmer.. why is it not bright?
yes i agree the TV lamp it's done.
a lamp last like arrownd 4000 ans 7000 hours depends on the lamp brand..
i will give you a link that u can used and a video so you can change it it's so easy
good luck!
http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi%20WD-73827%2073
Jan 15, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Panasonic 52 projection tv lamp light ?
Sounds like the lamp failed early (not uncommon) and one of the fans has something rubbing on it. Clean the interior and fan filters and replace the bulb (for lamp #TY-LA2005) as follows:
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Jan 10, 2008 | Panasonic PT-52DL10 52" Rear Projection...
258 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
