Tip & How-To about Televison & Video
How much will it be to replace my lamp?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How much will it be to replace my lamp?
It all depends on the type of lamp and manufacturer u has, some brands are compatible that is always a good thing.
Example:
LG, Zenith, Mitsubishi, RCA, Samsung, and some Panasonic they use. Philips so you can save money we just need to know if the model is compatible.
The cost is around $85.00 the cheap ones $114.00 Philips and like $299.00 again depends on the brand and ho is the one that sales!
There are a lot of good online stores that can send you a lamp usually for a lower price here are a few links that I can found if you need them.
http://www.discounttvlamps.com/
http://www.purelandsupply.com/
http://www.discount-merchant.com/
http://lamps4less.net/
good luck..
Televison & Video Logo
where can i buy lamp for sanyo lp-z5 projector
You can purchase at www.Nextag.com (just verify the part number first) Sanyo Genuine Original 610-323-5998 Projector Lamp Video Accessories: Projector Lamps, Projector Stands - General Audio & Video Accessories: Carts / Stands Part #: POA-LMP94 more ..., POALMP94 Sellers Found: 6 Available Since: May 26, 2008
Lowest Price: $185.00
Average Rating: star-gray-1.pngstar-gray-1.pngstar-gray-1.pngstar-gray-1.pngstar-gray-1.png Your Rating: ', Cancel:'cancel',AR:'Average Rating:'}); //--> (0 user ratings) No Reviews ' Write a Review Description 145W UHP - 2000 Hour Standard, 3000 Hour ECO Specifications Video Accessories Projector Lamps, Projector Stands General Audio & Video Accessories Carts / Stands Lamp Life 3000 Hour ECO, 2000 Hour Standard, 3000 Hour, 2000 Hour Manufacturer Part Number POA-LMP94 Brand Name SANYO Lamp Power 145 W Compatible Devices LCD Product Type 145 W UHP Projector Lamp, Projector Lamp UPC : 610074006343
Oct 08, 2010 | Eiki Sanyo Projector Lamp
How to replace Sony Wega KFWE42S1 lamp
Example:
good luck..
Apr 20, 2010 | Sony Grand WEGA KFWE42S1 TV
Mitsubishi WD-57732 LAMP continuously burns out. I have replaced four in two years. We don't watch alot of TV.
There are a few issues here:
The lamp you are purchasing could not be OEM, or a compatible lamp--OR you have a ballast/power supply issue blowing the lamp out.
The original lamp is manufactured by Osram, but a better and compatible lamp would be Philips, who pioneered the lighting for DLPs. The ballast needs to be compatible with the lamp and Mitsubishi ballasts are compatible with most lamps, but work best with Philips and Osram. Only buy from an authorized dealer!
Feb 04, 2010 | Mitsubishi WD-57732 Projection Television
THE LAMP IS A YEAR OLD
It depends on the type of lamp you used. There are a variety of replacement lamps available, but the only brand I recommend is OSRAM due to the quality problems with the other brands
Jan 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
148 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
