Tip & How-To about Televison & Video
When it's time to replace you TV lamp!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The screen will lose its brightness and depending and how much you use your TV.
You can wait till it loses all images or just change and buy some light for the future!
Televison & Video Logo
replaced lamp in 55vg825 approx 1500hrs ago & lately the picture has lost brightness compared to when the new bulb was installed. Is there another adjustment or is the bulb defective already? Past experience dictates the bulb either works or doesn't work.
bjac,
You are correct about lamps working or not, but that is the extremes. Over the course of operation all lamps lose brightness as the hours add up. All lamps will lose their brightness over time.
Typically lamps only last at best 6000 to 8000 hours. That is not long if the unit is used most of the day everyday. In addition the cheaper the quality of the lamp, cost and manufacture, the quicker they go down hill.
Assuming that you have a low quality lamp what you are experiencing is normal. You may be able to improve the brightness and clarity of the picture by cleaning the lenses, mirrors and screen. I have a tip at
http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv
This tip is labeled projection tv but is also appropriate for cleaning an LCD or DLP unit.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 14, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Brightness has decreased. What might be the problem be.
The lamp inside your tv is what provides the brightness for your screen.After so much usage the lamps lose brightness.Therefore your image will seem dimmer.You can go to discount-merchant.com to find the lamp you need.
May 06, 2010 | Philips 60PP9202 60" Rear Projection...
why is my toshiba 46h84 picture getting darker than before? Its becoming harder to see darker scenes in movies
It sounds like your lamp is getting close to the end of its lifespan.The lamp is what gives your screen its brightness.With time they start losing this brightness.If you were to wait to replace it till it goes out completely you would have a black screen.You can purchase a quality lamp at discount-merchant.com
Apr 16, 2010 | Toshiba 46H84 46" Rear Projection...
148 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
