Tip & How-To about Computers & Internet
Increase space on Drive C without any file delete?
It is very interesting thing, many peoples take tension due to that problem. Take patience and note it very carefully. When you install a new operating system and then you check your available sapce in that drive where you install OS. You feel tension because there is space problem, when you take properties of your Drive C (where you install OS), there is difference between properties of Drive C and Data of Drive C.
It is interesting and think about that how it is possible? You think that may be this is reason of a virus or trojen but this reason is totally wrong. We can overcome on this problem to follow these steps.
First Step:
>> Right click on Desktop and take properties and now press tab two times or click on screen saver and now tab or click on power.
>> There are four tabs, " Power Schemes, Advanced, Hibernate and UPS". Click on Hibernate and now uncheck on "Enable hibernation" and now apply and click on OK. The first step has been completed now.
Second Step:
>> Take properties of MY Computer and then click on advanced and now click on settings on top (Performance).
>> Click on once again Advanced, now click on change and then choose no paging file and then click on Set and then press OK apply and take a reboot on demand.
Dear you have been reduced your space on Drive C after taking reboot.
Enjoy!!!!!
Good Luck
Computers & Internet Logo
gearbox chatter on tick over do they suffer from dualmass problems also is there a quick way to change the cambelt
Dual Mass Flywheel, and will also need new clutch Remove the engine coverUsing a [16 mm], rotate the tensioner arm clockwise (about 14° )and remove the belt from the pulley.
Remove the power steering pump pulley, idler pulley, tensioner pulley and crankshaft pulley.
Remove the upper and lower timing belt covers.
Remove the auto tensioner.
NOTE
Rotate the crankshaft clockwise and align the timing mark to set the No.1 cylinder's piston to TDC (compression stroke).
At this time, the timing marks of the camshaft sprocket and cylinder head cover should coincide with each other.
Unbolt the tensioner to remove the timing belt.
NOTE
If you plan to use the timing belt again, mark the rotation direction on the belt so you reinstall it correctly.
SERVICE MANUAL
Applies to: Santa Fe 2004
GROUP
Engine Mechanical System Timing System
INSTALLATION
Install the idler pulley to water pump boss.
NOTE
Insert and install the idler pulley to the roll pin that is pressed in the water pump boss.
Install the tensioner arm and plain washer to the cylinder block.
Install the tensioner pulley to the tensioner arm.
Install the camshaft sprockets and align the timing marks.
NOTE
When installing the camshaft sprockets, fasten them tightly while holding the hexagonal part of the camshaft.
Before installing the timing belt, if the timing marks of the cam sprocket and the cylinder head cover do not coincide, do not rotate the cam sprocket more than 3 teeth in either direction.
Rotating the sprocket more than 3 teeth may allow the valve and piston to touch each other.
If the cam sprocket is rotated more than 3 teeth unavoidably, rotate the crankshaft counter - clock wise a bit before rotating the cam sprocket.
Install the auto tensioner to the front case.
NOTE
At this time auto tensioner's set pin should be compressed and secured with set pin.
Align the timing marks of each sprocket and install the timing belt in the following order. Crankshaft sprocket--> Idler pulley--> camshaft sprocket (LH side)--> Water pump pulley--> camshaft sprocket (RH side)--> Tensioner pulley.
NOTE
In this step, No. 1 cylinder is in the TDC (Compression stroke).
Be very careful if you use your fingers.
Pull out the set pin of the auto tensioner.
Install the upper and lower timing belt covers.
Install the power steering pump pulley, idler pulley, tensioner pulley and crankshaft pulley.
Using the wrench [16mm], rotate the tensioner arm clockwise (about 14°) and install the belt to the pulley.
Install the engine cover.
How to adjust the tension of the timing belt
Rotate the crankshaft 2 turns clockwise and measure the projected length of the auto tensioner at TDC (# 1 Compression stroke) after 5 minutes.
The projected length should be 6-8 mm.
Verify that the timing marks of each sprocket are in their specified position.
NOTE
If the timing marks are not in their specified position, repeat from 6 above.
Dec 28, 2010 | 2004 Hyundai Santa Fe
When should a chevy Impala transmission be serviced and what do they do to it? Thanks.
They remove the transmission pan,and let all the fluid run out,and change the filter,then install a new gasket on the pan,and replace the filter,install the pan,and fill the transmission back up.
Apr 20, 2010 | 2006 Chevrolet Impala
i need to know how to loosen a tensioner so i can take my serpentine belt off
find the tensioner pulley put a wrench on the bolt and you can release the tension from it
Jan 25, 2010 | 2003 Chevrolet Venture Passanger
what tools do I need to remove both engine belts from my wife's 2004 Concorde.do I need ome special tensioner tool to move the tensioner the other belt is a regular v belt and it goes around the airconditioner. but how and where do I losen taht belt. Larry
2.7L & 3.5L Engines same Tools & Procedure Rate Me Please 1/2 in. breaker bar & Special Tool 7198 for conventional V-belts and Poly-V belts
  1. REMOVAL
    AIR CONDITIONING BELT
    NOTE: The A/C drive belt self tensioner is NOT a dynamic tensioner. After adjustment the tensioner bracket bolts are tightened. The torsion spring is no longer responsible for tensioning the A/C belt. The torsion spring is only used for initial belt tensioning.
    1. Remove generator/power steering belt to gain access to A/C belt. Refer to GENERATOR/POWER STEERING BELT for procedure.
    1. Loosen BUT DO NOT REMOVE tensioner locking bolt and pivot bolt (Fig. 2).
    2. Insert 1/2" drive breaker bar into square opening on belt tensioner. Rotate tensioner counterclockwise until belt can be removed from pulleys (Fig. 2).
    3. Slowly rotate tensioner clockwise to relieve spring load.
    CLEANING
    Clean all foreign debris from belt pulley grooves. The belt pulleys must be free of oil, grease, and coolants before installing the drive belt.
    INSPECTION
    Belt replacement under any or all of the following conditions is required:
    • Excessive wear
    • Frayed cords
    • Severe glazing
  • Poly-V Belt system may develop minor cracks across the ribbed side (due to reverse bending). These minor cracks are considered normal and acceptable. Parallel cracks are not (Fig. 3).
    NOTE:
    Do not use any type of belt dressing or restorer on Poly-V Belts. INSTALLATION
    AIR CONDITIONING BELT - NEW
    WARNING: DO NOT REMOVE A/C BELT TENSIONER LOCKING BOLT WITHOUT FIRST HOLDING THE TENSIONER WITH A 1/2" DRIVE BREAKER BAR, AS PERSONAL INJURY COULD RESULT.
NOTE: Verify that torsion spring position is in the new belt position before installing a NEW belt (Fig. 4). If torsion spring is not in the new belt position, follow steps 1-7 to change the tensioner spring from the USED belt position to the NEW belt position.
  1. Insert a 1/2" drive breaker bar into the square opening on the tensioner. Hold counterclockwise pressure on tensioner while removing the locking bolt (Fig. 2).
  2. Carefully release spring load of the torsion spring on the tensioner.
  3. Remove pivot bolt, tensioner, and spring from front timing cover.
  4. Insert spring arm into the NEW belt position on the tensioner (Fig. 4).
  5. Install torsion spring, tensioner, and pivot bolt.
  6. Install pivot bolt. Tighten only finger tight, at this time.
  7. Using a 1/2" drive breaker bar, apply counterclockwise pressure until locking bolt can be installed.
    1. Install the NEW belt by rotating the tensioner counterclockwise until the NEW belt can be installed on pulleys. See (Fig. 5) for belt routing.
    2. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    3. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    4. Install generator/power steering belt.
    AIR CONDITIONING BELT - USED
    NOTE: A "used belt" is considered having more than 500 miles of service use. NOTE: Perform steps 1-7 to change the tensioner spring from the NEW belt position, to the USED belt position.
    1. Insert a 1/2" drive breaker bar into the square opening on tensioner. Hold counterclockwise pressure on tensioner, while removing tensioner locking bolt (Fig. 2).
    2. Carefully release the tension of spring on tensioner.
    3. Remove pivot bolt, tensioner, and spring from front cover.
    4. Insert spring into the USED belt position on tensioner bracket (Fig. 4).
    5. Install spring, tensioner bracket, and pivot bolt.
    8. Install the USED belt by rotating tensioner counterclockwise until belt can be installed on pulleys. See (Fig. 5) for belt routing.
    9. Release tensioner and remove breaker bar. Belt is automatically adjusted with the tensioner's torsion spring.
    10. Tighten tensioner locking bolt and pivot bolt to 28 Nm (250 in. lbs.) (Fig. 2).
    11. Install generator/power steering belt.
I Hope This is Of Help To YOU IF So PLEASE HELP ME RATE ME it Helps Thank You Very Much and Happy Motoring !!!!!!!!
Jan 21, 2009 | Chrysler Concorde Cars & Trucks
interior clock
The easiest solution is to insert a flat screwdriver blade under the sides of the 'clock - roof switch' 'panel' and gently rotate it. This will cause the panel to jump out of the retention arrangement.
Refitting is to simply press the panel into place.
The clock itself is retained by two side locating strips, into which the clock assembly fits. Don't forget to remove the power cable first, noting the orientation for refitting.
Of interest, I assume you have lost the display. In two instances I have repaired, it is due to some of the components on the clock pcb becoming disconnected. Have a close look with a magnifying glass, and resolder (with care) as required.
Jun 08, 2008 | 1998 Subaru Forester
290 people viewed this tip
David Payne
David Payne
