Tip & How-To about Cell Phones
How to connect a (Motorola) Blue Tooth headset to a mobile phone!
The following procedure is dependent to the phone in use! However it is mainly for Motorola brand but it works with many others too!
1. Turn on your mobile phones bluetooth function and go to search for new devices menu.
2. On the headset, From turned off state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on (or in other brands flashining very fast) which means the headset is in receiving/searching state!
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone (the light flashes slowly) and will be ready to receive calls!
Best wishes
Bruce
Cell Phones Logo
how do i run my motorola h505. I got it from a friend and have no idea how to use it.
the following procedure is dependent to the phone in use!
2. On the Moto headset, From turned of state, Try holding down the power button for at least 5 seconds.
now your headset should be paired with your phone and work for receiving calls!
Great Success :P
Bruce
Dec 07, 2009 | Motorola Mobility H505 BLUETOOTH HEADSET
want to unlock a motorola I305
Depending on your phone make and brand, remote unlocking can either be done via your phone's IMEI (serial number) or through downloading very easy to use software and running it on your computer while your phone is connected to the computer.
and
  • Unlock Type:Remote Motorola i305 unlock via cable and software, you will not have to mail in your Motorola i305 phone.
  • Cable Required:Yes, if you do not have a cable for your Motorola i305 simply select the option from the drop down menu below to have a cable mailed out to you (extra charge)
  • Turn around time: INSTANT Motorola i305 unlock instructions are delivered instantly after payment via EMAIL
  • Ease of Use: Easy , some driver installation is required, no other complications
  • Nov 07, 2009 | Motorola Mobility i305 Cellular Phone
    i'm not able to send data via bluetooth to other mobiles
    first make pair your mobile to other mobiles ..after that try to send via bluetooth ..
    Sep 11, 2009 | Nokia N73 Cellular Phone
    What do I do if my screen stops working?
    i know
    i have that problem too in my motorola V3
    well, you must to change the co called "flexy cable" that conected your phone's LCDs to main system of phone
    it's cost about 9$ without labour fee
    Jan 24, 2009 | Motorola Mobility RAZR V3
    115 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
