Tip & How-To about Drills
Slipping screw driver
How often have you been screwing a screw and the screwdriver repeatedly slips out of the screw slot.
If you have a pool table take one of those old que chalks and rub it on the tip of the screwdriver. No more slipping!! I keep a chalk in my tool box.
Drills Logo
How do I fix one of the frame support buttons on a Bugaboo Cameleon, as the lefthand button is stuck?
Do you mean the tilt buttons? If so you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a phillips. Here's the process: 1. Behind the white button is a screw. Remove it using the phillips screwdriver. 2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver. 4. You'll now have a black base, a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea. 6.Reassemble and repeat for the other side.
Jan 16, 2011 | Bugaboo Cameleon Jogger
How do I remove links?
You will need a very small screwdriver.
Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. disassembly2.gif Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. disassembly3.gif Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side.
Aug 20, 2010 | Pulsar PC3011 Wrist Watch
pump leaking
Some impellers have a screw in the middle which screws into the centershaft with reverse threads. If it has one, unscrew that first. Next, there is either a flat on the shaft near the opposite end or there is a slot in the end of the shaft for a screwdriver. Hold the shaft securely, and unscrew impeller. Sometimes a big pair of pliers is needed, but be careful not to damage impeller.
Jul 22, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
May 01, 2009 | Pool & Spa
880 people viewed this tip
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
