Tip & How-To about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Electronic appliances
If you have an electronic board on your machine put a surge protector on it. it will save you alot of money because just a little power surge will blowup an electric control board of any kind
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
Please tell m e how to turn on the tv manually...went out after a power surge, red light not on and the remote wont work.
there is an on/off one the side but quite likely the set will not start ,needs to go to repair shop or be replaced.
Nov 02, 2015 | Televison & Video
my kenmore elite calypso will not do final spin.flashes LD. I replace the pump as was suggested,still did not fix froblem
Hello Alex;
My name is Peter. I am a retired field service appliance technician.
After review of your washer components, there is a strong possibility that you have a bad electronic control board. You have two control boards, one is for the motor and one for the other functions.
Washer electronic control board for Kenmore Elite Washer model #11021062001 Electronic control board 8571359 is the circuit board that manages the washer's functions, such as filling, washing, draining and spinning. It sends voltage to the drive motor and other electro-mechanical component.
Cost: $218.00
If you elect to replace the board make sure you ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock a board out.
All appliances with electric control boards should have a surge protector. You can purchase a wall socket surge protector for $20-25.00. It is a good investment considering how expensive control boards are.
Rule of thumb; "If the unit is either 7 years old or the cost of repair is 1/3 or more of the original price, purchase a new unit.
Consider it purchasing a new unit, stripping your existing unit for parts to sell on e-bay. You will make a little money and save others expensive parts cost.
Dec 03, 2014 | Kenmore Washing Machines
after an electrical storm the vcr combo do not come on
johngreen,
Unfortunately this is a worst case scenario. Electrical storms with electrical surges can wreak havoc on all electrical devices if they are not protected with a surge protector. The bad thing is it will cost to more money to have the board replaced as opposed to buying another unit. In the future it is best to invest in a surge protector and protect all your electronic devices. Thanks for visiting FixYa.com.
Sincerely,
TechGuy21
Jul 05, 2011 | Magnavox DV225MG9 DVD Player VCR
The main board in my Haier HDN455 is dead. I have power to it, then none of the power lines leaving are hot. We had a power outage and it went after that. Any luck in finding a new one?
The applaince parts companies that I work with do not provide a replacement main board. You can write or call the manufacturer to try to get a replacement main board.
These problems occur because of voltage spikes that occur during power outages and lightening storms. You should consider installing whole house surge protection.
All of your electronic equipment is subject to damage; investing a couple hundred dollars for a good surge protector may save you $1000s of dollars in the future.
I am a licensed Master Electrician, and I provide fee-based DIY assistance. The fee is based upon the scope of work. The fee for assistance in installing a house surge protector is $25. Please go to http://taeckertindustries.com/serv01.htm to obtain DIY assistance
Sep 19, 2009 | Haier HDN455 45 Pint Dehumidifier...
i turn the tv and inside star a shortcut with smoke
Ur tv circuit board is burn or ur power board is dead. Make sure ur TV worth repairing it cost alot money for this prob.U know little about
Electronic u can check if there no burn in the circuit board check the plug go to the power u can buy that board in the net might work might not.Could burn alot of things in power surge.
Aug 12, 2009 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
2,906 people viewed this tip
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
