Tip & How-To about Computers & Internet
Create a Hidden User Account This tweak allows an account that is normally displayed on the Welcome screen to be hidden from view. To log on using the account it's necessary to use the Log On To Windows dialog box similar to the one in Windows 2000 i.e. press CTRL+ALT+DEL twice. [Start] [Run] [Regedit] Go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon\SpecialAccounts\UserList Modify/Create DWORD Value of Data type REG_DWORD Named [Type Name of Account to be Hidden] Setting for Value Data: [0 = Account is Hidden / 1 = Enabled] Exit Registry / Reboot While the account is hidden on the Welcome screen, note that the account profile will be visible in C:\Documents and Settings or wherever user profiles are stored as well as in Local Users and Groups.
Computers & Internet Logo
can t open my dell inspiron 1440 old one
For its time it was a good spec with Vista 64 and 4GB RAM and should still work well today. Three options.
1. Try logging into the administrator account in safe mode.
Start your PC and press F8 repeatedly before Windows loads to open Vista's Boot Options screen.
Select Safe Mode and press Enter.
On welcome screen choose the Administrator account, which by default has no password. Just hit return.
Goto Start / Control Panel / User Accounts and create a new user account with admin privileges
Close and restart PC and log into the new account.
2. Use a password recovery program
The following link shows 8 free password recovery programs.
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
3. As a last resort reset to factory defaults. Dells normally come with a hidden recovery partition.
Either boot from the recovery disks you created or use the hidden partition for a fresh install.
To do a factory restore,on startup press Ctrl + F11 which will take you to the recovery partition so you can do a factory restore. This will then create new user accounts.
Good Luck
Jul 08, 2014 | Dell Inspiron Laptop 1440
Remove User Accounts from the Login Screen in Windows XP So you login to your computer every single day, but there?s morethan one account to choose from? either because you got the computerfrom somebody else, or some software package added a user account thatyou really don?t want to see. So how do we hide that other account fromthe login screen? There?s a simple registry that you can do to hide accounts fromthe login screen, or you could alternatively delete the user account ifyou really don?t need it. Both methods are listed below. Open up regedit.exe through the start menu Run box, and then navigate down to the following key: HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NT CurrentVersionWinlogonSpecialAccountsUserList On the right-hand side you?ll see a list of keys that correspond touser accounts that are considered ?Special? and are not to be shown onthe login screen Create a new DWORD value with the same name as the user name thatyou want to hide. You?ll note that the actual username in theillustration was ?OtherPerson? and not the description that was shownon the login screen. To unhide the account, simply delete the registry key that you created. The next time you log off you?ll see that the other account is gone. Hide User Account with Tweak UI You can also use the Microsoft Tweak UI PowerToy to do the same thing. (Thanks to Gustav for reminding me to include this) Just click on the Logon key in the left hand side, and then uncheck the box for ?Show on Welcome screen? Login to Hidden Account You can still login to the account even though it?s not shown? You?ll just have to use a little trick. At the login screen, just hit the Ctrl+Alt+Delete combination twicein a row, and you?ll be presented with the old-school login screen,where you have to manually enter the username. Type the name and password of the other user, and login. Delete User Account Alternatively you can always delete the user account if you areabsolutely sure that you don?t need that user account anymore.Right-click on ?My Computer? and choose ?Manage? Navigate down through ?Local Users and Groups? and then Users, and thenlocate the username in the list that you?d like to get rid of. Just right-click and choose Delete. Note that this step cannot bereversed, so make sure you only delete accounts you really really don?twant anymore. If you are unsure, you can just hide them using the firstoption above.
Jun 24, 2010 | Computers & Internet
How do I logon as administer
The built-in Administrator account is hidden from Welcome Screen when a user account with Administrator privileges exists and enabled. In Windows XP Home Edition, you can login as built-in Administrator in Safe Mode only. For XP Professional, press CTRL + ALT + DEL twice at the Welcome Screen and input your Administrator password in the classic logon window that appears.
To have the Administrator account displayed in the Welcome Screen, try one of these methods:
Method 1: Using TweakUI Power Toy for Windows XP Download TweakUI from here: v2.00 for Windows XP | v2.10 for XP SP1 and above
Open TweakUI and click "Logon" option in the left pane. Put a checkmark against the option "Show Administrator on Welcome Screen". Click OK to close TweakUI. Logoff and see if Welcome Screen lists Administrator login. Changes are immediate and you can use the Winkey + L to switch back to Welcome Screen to see Administrator account is listed.
Use this procedure to hide/unhide any user account from the Welcome Screen. Please remember, you can still login to a hidden account using CTRL+ALT+DEL classic logon method, but cannot Fast User Switch to a hidden user account.
Method 2 - Manual registry edit
  • Click Start, Run and type Regedit.exe
  • Navigate to the following key:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon \ SpecialAccounts \ UserList
  • Use the File, Export option to backup the key
  • Create a new DWORD Value named Administrator
  • Double-click Administrator, and set 1 as its data
  • Exit the Registry Editor.
For Windows XP Home Edition While you can configure Windows XP Home Edition to show Administrator account in the Welcome Screen, you cannot login as Administrator in Normal mode. Visit the following link for more information:
Error Message: Unable to Log You on Because of an Account Restriction
Please post your feedback and Vote if the problem resolved as per your satisfaction.
May 20, 2010 | Computers & Internet
no rights to run control panel requires new instal need media
1. to gain rights do the following.
Sep 17, 2008 | Computers & Internet
169 people viewed this tip
David Payne
David Payne
