Tip & How-To about Computers & Internet
Create a Personal Screen Saver in Windows XP!
This isnt a tweak, but a great little feature! For a great way to put your digital photos to work, try creating a slide show presentation for use as a screen saver. Here's how:
1.) Right-click an empty spot on your desktop and then click Properties.
2.) Click the Screen Saver tab.
3.) In the Screen Saver list, click My Pictures Slideshow.
4.) Click Settings to make any adjustments, such as how often the pictures should change, what size they should be, and whether you'll use transition effects between pictures, and then click OK.
Now your screen saver is a random display of the pictures taken from your My Pictures folder.
Good luck & Have Fun!
Computers & Internet Logo
) What feature of Powerpoint 2010 helps in broadcasting slides to remote audience
Dear Anand,
To broadcast your presentation, do the following:
  1. On the Slide Show tab, in the Start Slide Show group, click Broadcast Slide Show.
The Broadcast Slide Show dialog box opens.
  1. Do one of the following:
    • If you want to host your slide show on the service listed under Broadcast Service, skip to the next step.
    • If you want to use some other service to host your slide show, click Change Broadcast Service. Under Choose a broadcast service, select the service that you want to use. For more information about broadcast services, see Choosing a broadcast service.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
  1. After you select your broadcast service, click Start Broadcast. PowerPoint then creates a URL for your presentation.
PowerPoint creates a unique URL for your slide show.
  1. To send the URL for your presentation to your audience, do one of the following:
    • To send the URL for your presentation by email, click Send in Email.
    • To copy the link, click Copy Link.
  2. When your audience receives the URL for the slide show, click Start Slide Show to begin your broadcast.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
  1. After you finish presenting and are ready to end the broadcast, press ESC to exit Slide Show view and then click End Broadcast.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Regards,
Tech_Comp
Feb 23, 2011 | Microsoft PowerPoint 2010
flash
Easy, friend. There are many free software to make it.
One I just discovered is jtvmaker, download it here:
http://www.softpedia.com/progDownload/Jtvmaker-Download-92917.html
It will create very cool slide shows and albums.
Other flash slide show maker, you can use Advance Effect Maker (freeware edition), download here:
http://www.effectmaker.com/application/
Another choice you may try: Easy Slide Show Creator
http://www.download.com/Easy-Slide-Show-Creator/3000-2189_4-10148015.html
Let me know if you have problem in using it.
Feb 09, 2008 | Adobe Photoshop 7.0 for PC
125 people viewed this tip
David Payne
David Payne
