Tip & How-To about Computers & Internet
DVD not working fix for Vista
Windows Vista
  1. Click Start , and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Computers & Internet Logo
i have acer 7520 and i don't see the dvd rom in windows explorer
It happens when the Software that is not Windows Vista capable (such as printer software, CD burning software, and games) may have modified the registry to cause the optical drive to not function.
Please follow the steps below:
  1. From the Windows Vista default Start menu, point to All Programs, Accessories, and then click Run.
  2. In the Run dialog box, type: Regedit. Click OK.
  3. In the User Account Control dialog box, click Continue.
  4. In the Registry Editor window, locate and then click to select the following registry subkey: HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
  5. From the File menu, click Export.
  6. In the File name dialog box, type: Savedkey, and then click Save.
  7. Click the REG_MULTI_SZ data type UpperFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
  8. Click the REG_MULTI_SZ data type LowerFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
  9. In the Registry Editor window, from the File menu, click Exit.
  10. Shut down Windows® and restart the computer.
Thanks and regards,
Anil.B.R
Aug 17, 2010 | Acer (4432A-002) CD-RW Burner
1606 error code, launcher not working , running vista
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. Locate and then click the following registry key:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  4. In the right pane of Registry Editor, double-click Common Administrative Tools.
  5. In the Value data box , type the following line, and then click OK: %ALLUSERSPROFILE%\Start Menu\Programs\Administrative Tools
  6. On the File menu, click Exit to quit Registry Editor.
  7. Restart the computer.
refer to:
http://www.ikarmatech.com
Sep 08, 2009 | Microsoft Windows Vista Home Premium with...
windows vista
1. Disable Windows Update
a. Click on start
b. Click on all programs
c. Click on accessories
d. Click on Run
e. Type services.msc and press ok
f. Right click on "Windows Update"
g. Click on stop (Windows Update is now disabled)
2. Rename Software Distribution folder
a. Navigate to: C:/Windows/
b. Find the folder named: “SoftwareDistribution”
c. Rename that folder to something like “SoftwareDistribution.old”
d. Create a new folder called “SoftwareDistribution”
3. Enable Windows Update
a. Click on start
d. Click on Run
f. Right click on windows update
g. Click on start
If you are unable to find Software Distribution Folder, follow these steps before #2 above.
1. From the explorer window press the Alt key to view the file menu.
2. Click Tools
3. Select Folder Options
4. Select the View tab
5. Select “Show hidden files and folders”
6. Remove the selection from “Hide protected operating system files”
7. Click OK
Restart your PC and you should be good to go!
Jan 09, 2008 | Microsoft Windows Vista Ultimate Edition
148 people viewed this tip
David Payne
David Payne
