Tip & How-To about Computers & Internet
DVD drive not working fix for XP
Windows XP
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Computers & Internet Logo
I need to enter a new product key after xp is already installed how can I do this?
I recommend that you run System Restore to create a new restore point before you follow these steps.
First of all you need to decative Windows and reactivate it.
Deactivate Windows loadTOCNode(4, 'moreinformation');
  3. In the navigation pane, locate and then click the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents
  4. In the topic pane, right-click OOBETimer, and then click Modify.
  5. Change at least one digit of this value to deactivate Windows.
Reactivate Windows and add new product key loadTOCNode(4, 'moreinformation');
  2. In the Open box, type the following command, and then click OK. %systemroot%\system32\oobe\msoobe.exe /a
  3. Click Yes, I want to telephone a customer service representative to activate Windows, and then click Next.
  4. Click Change Product key.
  5. Type the new product key in the New key boxes, and then click Update.
    If you are returned to the previous window, click Remind me later, and then restart the computer.
  6. Repeat steps 1 and 2 to verify that Windows is activated. You receive the following message: Windows is already activated. Click OK to exit.
  7. Click OK.
Mar 09, 2010 | Microsoft Windows XP Professional Full...
CD/DVD drive will not read any discs. I tend to believe it is shot. Expensive to fix??
try this first. Windows XP Click Start, and then click Run. In the Open box, type regedit, and then click OK. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} In the right pane, click UpperFilters.
it is not too expensive IF it is the DVD.
Feb 21, 2010 | Gateway MX6955 Notebook
Drive disappear. shows yellow exclamation marks
This article might help you in fixing the error code 19. I have tested this one and it worked for me. The error means that the optical driver got corrupted.
Microsoft Windows Vista
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Jan 30, 2010 | Dell 8X DVD-ROM Drive for Precision...
115 people viewed this tip
David Payne
David Payne
