Tip & How-To about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
It make my PC not stable when using them
I bought this usb adapter for 2 months, it can get all signal around my house but when i used them it make my PC not stable such as it cannot play mp3 or any kind of music properly.
Yesterday i tried to figure it out why my PC is not stable and i took the wireless usb out... now my PC works well without the wireless usb.
how can i solve this problem???
is it driver problem??? if anyone has the latest driver please help.
Thanks..
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to rectify this problem, Please help me out.
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
recieving an invaild pointer address message when
try looking for bluetooth and make sure your phone is compatible with it
Jul 19, 2009 | Adapters.com Bluetooth USB Adapater, USB...
Mouse thinks its alive (GE wireless optical 97990 rev.4)
Could be signal interference or overloaded usb port. Move receiver around to get a more direct signal, and notice any other devices in use like phones. Use alone without other usb devices plugged in and/or buy usb hub with power adapter. DO NOT buy passive usb hub with no additional power.
Nov 18, 2008 | GE Wireless Optical Mouse
1,277 people viewed this tip
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
