Tip & How-To about Computers & Internet
How to make your computer run faster for free!
Imagine that you have bought a computer that runs adequately fast. However, after a few weeks or couple of months you notice that your computer is not running as fast as it was when you first bought it.
One solution that someone may think is to buy new hardware (new processor, more RAM, bigger hard drive etc)
However before doing that try the following:
First of all go to Start, All Programs, Startup. If this contains items that you do not need you can delete them. These are just shortcuts and not the actual applications. Think if you need these applications to begin everytime you start up your computer. If not then remove them from that menu list.
Second thing you can try is a little bit more advanced:
Go to Start, Run and type msconfig and press enter.
In the dialog that opens go to Startup and see the long list of applications that startup everytime you boot your computer. You should only leave your antivirus program, and entries under the c:\windows\system32
If you are not sure about an entry leave it there or check it over the internet.
Then click on services and click Hide microsoft services. Check again which services should not be enabled and disable them. Use google again if you are not sure about the listed services.
Lastly, right click on MyComputer, select Properties. Go to Advanced tab and under performance click Settings.
Select Adjust for best performance
That's it. You should have a computer/laptop running faster.
Computers & Internet Logo
1998 dodge dakota 2.5 Sometimes it will just cut out for a second like it has no power. it will stall sometimes and always start back up tho after waiting a few seconds ive noticed when i go over bumpes on the road or when i ecellerate fast it cuts out i just drove 11 hours with it when i was stuck in a traffic jam it got alittle hot and it stalled then. its a manual by the way i dont know if that has any thing to do with it tho.its throwing a code ignition/distribitor circuit im not sure what that is?and dont want to go to a dealer unless i have too.
10/2013: Bought 1998 Dodge Dak 2.5. Has been stalling out since day one. Had every possible part that we could imagine replaced all named above and still problem. Finally took to Dodge Dealership and they said it's a "Rocker." Don't know what that is. Does anybody know? But all those "solutions" above have been done and replaced. Had to take directly to Dodge to finally get it figured out after months and months of expense and pure "H."
Sep 11, 2013 | 1998 Dodge Dakota
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
127 people viewed this tip
David Payne
David Payne
