Tip & How-To about Dryers
Dryer Running, Will not heat
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
Dryers Logo
Dryer runs but does not got hot, therefore does not properly dry clothes. I checked the heater element and it is good. Any suggestions?
Jan 10, 2011 | GE WSM2420T Top Load Stacked Washer /...
not heating
Also check my tip on thermal fuse locations
Jan 09, 2011 | Whirlpool Dryers
My dryer will not produce any heat ? it is only air drying. Is there an element I need to replace or a fuse ?
Jan 08, 2011 | Whirlpool LER4634J Electric Dryer
The dryer isn't heating up. Air circulation is good. What's the most common cause and what are the steps to disassemble the cabinet?
the most common problem is a bad thermal fuse,and it is possable that the heating element has gone bad.
1 you will have to remove the lid
2 remove the four screws that hold the control panel in place,then remove the foru screws that hold the front panel in place.then open the door to remove the two screws that also hold the panel in place then it will come off.
3 once you get in the cabinet then you will need to check the thermal fuse on the heating element can furthest to the back wall of the dryer if it does not have any continuity then it will need to be replaced.you will also have to check the heating element for continuity.
there is also a black thermal fuse located on the blower housing that can be bad but this usually will display a fault code.
Dec 11, 2010 | Samsung DV328AG Gas Dryer
no power of any kind
This is commonly caused by a blown Thermal Fuse. The fuse is a small white component mounted on the blower fan assembly. There should be two wires running to it. UNPLUG the dryer and disconnect the component wires before taking any resistance readings. You should read something close to 0 ohms with a multimeter if the fuse is good. If the fuse reads bad, you must replace it.
The location of your blower fan housing depends upon the MODEL NUMBER. Since you posted no model, the easiest way to determine where these components are is by the location of the dryer lint screen.
If the lint screen is on TOP of the dryer, all your heating circuits are BEHIND the dryer. Just remove the back panel to access. The blower fan housing will be located on the lower left hand side.
If the lint screen is in the DOOR of the dryer, the heating circuits are INSIDE the dryer cabinet under the drum. You will need to remove the lower toe panel under the door for access. If the dryer has a solid front with no lower panel, you must lift the dryer topand remove the entire front panel for access. The blower fan housing is on the left hand side of the cabinet under the drum.
The following link can give you some more guidance on dryer no power issues:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
Refer to the section that explains the possible components for "Dryer Does Not Run At All". The Thermal Fuse is the most common cause, but there are other possibilities to consider.
Now...if the thermal fuse has blown, it usually blows for a reason. The most common cause is poorly installed, kinked or clogged exhaust vent ducting. I would strongly recommend you thoroughly inspect the ducting, air blower and cabinet interior before replacing any defective components. Otherwise, these same components will fail again.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Mar 30, 2010 | Whirlpool Dryers
279 people viewed this tip
Top Dryers Experts
Dan Webster
Dan Webster
