Tip & How-To about Dryers
Taking to long to dry
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Dryers Logo
Dryer functions seem normal, barrel rolls, air is circulating and it feels hot, however clothes are not dry after several cycles/hours.
Mar 06, 2011 | Whirlpool LEQ9858P Electric Dryer
dryer heats and turns but doesn't completly dries clothes
Feb 13, 2011 | Kenmore 600 6965 Electric Dryer
Electric dryer runs, drum turns, gets warm, cleaned out vent, but still not getting clothes dry.
Feb 13, 2011 | Maytag Dryers
dryer taking too long to dry clothes
Jan 09, 2011 | Maytag MED5700TQ Electric Dryer
Frigidaire Front Load Dryer Model # leq2152eeo Problem: it is not drying the clothes. The dryer heats up and everything else is working, except it takes 4 cycles to dry something that should have dried in 1 cycle.
while the dryer is running.go to the outside of the house and check the air flow,there should be a large amount air being blown out if there is not check the vent and ducting for lint build up and make sure the hose is not kinked.
when there is restricted air flow all the warm moist air will stay in side the dryer causing the clothes to take a long time to dry. i hope this helps you with your dryer
Jan 24, 2010 | Dryers
401 people viewed this tip
Top Dryers Experts
