Tip & How-To about Computers & Internet
How to remove unwanted files from your hard drive to increase computer speed and function
This instruction will help you remove unnecessary files from you hard drive. Generally these are temporary files that the computer generates whenever you perform a task on the computer. An example would be searching the internet and making a word document. Follow the instructions below on a regular basis to keep unwanted files from clogging up your hard drive.
Double Click on My Computer, you will open a window showing all your drives.
Right click the “C” Drive, you will get a menu
Click on Properties
Look for “Disk Cleanup”
The system will start searching for unneeded files
A window will come up showing a list of files that can be deleted
Delete Temporary Internet Files, Temporary Files, Cookies and a any other files you recognize as unnecessary.
Click OK and the files will be deleted.
Keeping your hard drive uncluttered as much as possible will help keep your PC functioning at peak capacity.
I hope that you have found this tip useful.
Computers & Internet Logo
computer is slow
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 08, 2013 | Computers & Internet
why Mozilla Firefox are whenever crash& hang in my computer?
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking startall programsaccessoriessystem tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
Aug 03, 2013 | Mozilla Firefox
slow processing
Acer brand laptop computers are designed to be small, portable units that are great for logging onto the Internet and checking email on the go.
As your Acer laptop ages, you may start to notice that it runs a little more sluggish than it used to. As Acer brand laptops run on the Windows operating system, luckily there are a few built-in tools that you can use to boost performance and generally speed up your machine without spending any additional money.
Use the "Disk Cleanup" tool. This tool is built into all Acer laptop computers and is accessible by clicking on "Start," then "Programs," then "Accessories," then "System Tools."
Disk Cleanup will remove any files left behind by programs on your Acer laptop computer that are no longer needed.
This can free up valuable hard drive space and generally give your Acer laptop computer a bit of a performance boost.
Use the "Disk Defragmenter" tool.
As with Disk Cleanup, this tool is built into all Acer laptop computers and is accessible through the same folder in the "Start" menu.
Disk Defragmenter physically rearranges the way bytes of data are stored on your hard drive, making it easier for your operating system to access pertinent information.
As it will take your computer less time to find the information you're requesting, your computer will speed up a great deal.
Get anything you can off of your hard drive. In order to keep the price down, Acer laptop computers tend to come with smaller hard drives than full sized laptops.
As a result, hard drive space can be very precious.
The more data is stored on a hard drive the longer it will take your operating system to sort through everything and find the files you're trying to access.
If you empty any files you don't need onto a flash drive or external hard drive, you can generally improve the speed of your Acer laptop computer a great deal.
also
this should speed up your computer
Aug 02, 2013 | Acer Extensa Computers & Internet
usb speed 900kbps
try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
Mar 12, 2013 | Computers & Internet
wd hdd is very slow
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit
Jan 28, 2013 | Western Digital WD Scorpio WD3200BEVT hard...
263 people viewed this tip
David Payne
David Payne
