Tip & How-To about Video Game Consoles & Games
How to connect to Xbox Live wirelessly
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
Video Game Consoles & Games Logo
trying to connect to x box live. just bought the
Okay so here we go!
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
Jan 18, 2010 | Microsoft Wireless Network Adapter Xbox...
how do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay so here we go!
Jan 16, 2010 | Microsoft Wireless Network Adapter Xbox...
how can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay so here we go!
Hope this tip helps :).
Dec 31, 2009 | Microsoft Wireless Network Adapter Xbox...
need help connecting xbox live to the internet, have the wireless router but nothing is successful
Okay so here we go!
Dec 29, 2009 | Microsoft Xbox 360 Console
having problems hucking up to xbox live
Okay so here we go!
Dec 25, 2009 | Microsoft Wireless Network Adapter Xbox...
624 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
