Tip & How-To about Computers & Internet
How to check the PC system for errors, repair the damages or check disk.
1.) Go to 'Start'
2.) Press run and type CMD
(You will see a box eg: C:WINDOWSsystem32CMD.exe )
3.) Type CHKDSK , press enter
*CHKDSK is verifying files (stage 1 of 3) You have to wait for a few seconds/minutes.
Then you will get a message 'run chkdsk with /F (fix) option to correct these'.
4.) Type CHKDSK /F . press enter
( *Remember there is a space between Chkdsk and F: chkdsk/F )
Again, you will get a message 'chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
5.) Type Y
You will get a message ' This volume will be checked the next time the system restarts.
6.) Now, exit the box and restart your computer.
It will the check the disk. You will see this on your screen as you restart 'A disk check has been scheduled. Windows will now check the disk (stage 1-5)'
*Note: It will take some time to check your system disk. You need to perform 'check disk' regularly so that you can speed up your PC performance and to repair damages in your system.
* You can try it on any kind of Windows PC.
Computers & Internet Logo
yahoo chat box blank
*lights cigarette*
You may need to register vbscript.dll and jscript.dll
Follow the instructions below:
1.Run cmd.exe with administrator privileges (Start > type 'cmd' then right click on cmd.exe and select Run as Administrator, then click Continue when prompted by the elevation consent dialogue box). This will open a command prompt in c:\windows\system32
2.Type cd..
3.Type "cd SysWOW64" (Without The Quotes) press Enter
4. Type "regsvr32 vbscript.dll" (Without The Quotes) press Enter
You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
5. Type "regsvr32 jscript.dll" (Without The Quotes) press Enter
You should now get a message that says: "DllRegisterServer in jscript.dll succeeded."
Restart Your Computer.
Now try running Yahoo!
Regards,
Tamim
Jul 21, 2012 | Yahoo Messenger
Do any know how to run the Chkdsk Utility on a Dell Dimension 3100C Computer. SAny help would be appreciated.
Goto the Start menu and in the search or run box type cmd and press enter. Then in the black box that appears type chkdsk and press enter.
Feb 15, 2012 | Computers & Internet
We have windows xp and right now when we boot up the computer this window pops up saying google update.exe-corrupt file(window)then below it THE file or directory c;\windows\temp\gur3.tmp is corrupt and unreadable.Please run the chkdsk utility.WHAT SHOULD I DO? ;
You need to run CHKDSK from a command prompt window.
Open the start menu and click 'run.' In the text box, type 'CMD
In the command prompt window type CHKDSK /r and press enter. It will ask if you want to run at next start up enter y and press enter.
PLEASE NOTE there is a space between the K and //.
Reboot PC and CHKDSK will run and fix the error.
Dec 12, 2010 | Dell Dimension 2400 PC Desktop
when i want to turn off the computer, the pc will not shut down u
Hey,
try to run CHKDSK:
1. Click Start, and then Run.
2. Type cmd, and then press ENTER.
3. At the command prompt, type:
chkdsk drive: /f /r
Jan 07, 2009 | Microsoft Windows Vista Ultimate Edition
206 people viewed this tip
David Payne
David Payne
