Tip & How-To about Microsoft Windows XP Home Edition
Batch downloading multiple web pages
Looking for a way to download multiple web pages, images or other files from web sites without using a browser?
First, download and install URL2File Windows Application, which is the program we'll be using in this example (URL2File Windows Application is a product of Chami.com). URL2File can retrieve and save the content of a given World Wide Web URL to a local file. So, to retrieve the web page at http://www.chami.com/tips/ and save it to a local file named tips.htm, run the following command from a Windows Command Prompt/DOS Box:URL2File http://www.chami.com/tips/ tips.htmNote the format of the above command: URL2File followed by the web page/file address and the name of the file that you want to save the content as.The next step is to create a batch file that can call URL2File for eachfile you need to download. A Windows batch file is a text file with alist of commands, usually with the .BAT extension.Let's assume that there are three files named file1.zip, file2.zip and file3.zip at http://www.chami.com/tips/ that you need to download. To create a batch file to download above files:
  • Open Windows Notepad
  • Enter following three commands into the blank notepad (one command per file to be downloaded):URL2File http://www.chami.com/tips/file1.zip file1.zip
    URL2File http://www.chami.com/tips/file2.zip file2.zip
    URL2File http://www.chami.com/tips/file3.zip file3.zip
  • Save the notepad file with a name of your choice followed by .BAT ("download.bat" for example)
Now run "download.bat" from your Windows Command Prompt/DOS Box by typing:downloadand hitting ENTER. The newlycreated batch file will call URL2File three times for each of the threefiles and sequentially download them for you. To download other files,simply modify the batch file and run it again.
taken from http://www.chami.com/tips/windows/062598W.html
Microsoft Windows XP Home Edition Logo
How do I add multiple Digital photos from my PC to my Squarespace webpage?
Plug your USB Memory Stick into your computer and go to My Computer to open it and locate your photos. Open your internet browser and go to your Squearspace site and log in. If you're using a Gallery Page, you may go to your Pages panel, click on your Gallery Page and drag your photos from your Memory Stick to the browser window to upload them. Squarespace has a step by step guide here > Using the Gallery Page
Jan 12, 2015 | Computers & Internet
DOWN load pictures to computer
right click the required content image or picture in the Internet explorer or any other web browser you are using and choose "save as" to save it in your computer location.
If you are referring to the Movies then you can use the Torrentz search and then download the required movie. It is required to install the "Bit torrent" application in the computer before you need to use this feature. You can download multiple images in one file using this application.
Enjoy.
May 26, 2011 | Computers & Internet
Some sites the scroll down speed is really slow. It seems like text pages are ok and ones with images really slows the scroll responce down. Any ideas??? Thanks!!
Sounds like you are having problems with your Internet connection speed.You could try some of these tips..
  • Step 1 Click Start > Control Panel > Network and Internet Connections.
    Select "Internet Options."
    Under Check for newer versions of stored pages, click "Automatically." Under browsing history, click "Settings."
    If you're using dial-up, set the number under Disk Space to Use to between 250 and 1024 megabytes (MB). If you're using a DSL or cable connection, set it between 50 and 75 MB. Click "OK."
  • Step 2 Select "Delete" under Browsing history.
    Click "Delete files..." under Temporary Internet Files to clear your browser cache.
    Click "Delete cookies..." to remove all cookies from your hard drive.
  • Step 3 Disable any browser add-ons you don't need. In Internet Options, click "Programs." Click "Add-ons currently loaded in Internet Explorer." Select the name of the add-on you don't want to load, and select "Disable" under Settings at the bottom of the dialogue box. Avoid deleting ActiveX controls as this will most likely cause the browser to prompt you each time you encounter content on the web, such as Flash animations, that use that control.
  • Step 4 Switch to a faster browser. While Internet Explorer is the most popular browser, it often causes pages to load slowly. Download a free browser such as Firefox, Opera or Chrome to get a quick speed boost to your browsing.
  • Step 5 Disable images in your browser. To disable images in Internet Explorer, open Internet Options and click the "Advanced" tab. Scroll down to "Multimedia" and uncheck "Show Pictures."
    To disable them in Firefox, click Tools > Options in your browser window and select "Content." Uncheck the box beside "Load images automatically."
    To disable images in Opera, open the arrow beside the camera icon at the bottom of your browser, and select "No images."
    To browse with Google Chrome without images, right click on the Chrome shortcut and place the switch "-disable-images" without quotes after the last quotation mark in the path of the file.
  • Step 6 Disable active content if you're still experiencing a problem with your browsing speed. Return to the "Advanced" tab in Internet Options. Uncheck the boxes beside "Play animations in webpages" and "Play sounds in webpages."
  • Aug 11, 2010 | Dell SP2309W 23-Inch LCD Widescreen...
    combine webpages from multiple computers at one websie
    1) Open your web page code in a web editing application like Adobe Dreamweaver.
    2) Place the cursor in the section of your HTML code where you want the multiple websites to appear.
    3) Type "<iframe src ="www.site1.com" width="x" height="y"> </iframe>" (without the outermost set of quotes) into your HTML code.
    4) Replace "www.site1.com" with the web address of the first site you want to include on your web page.
    5) Replace "x" and "y" with the pixel dimensions that you want to use for each website on your page.
    6) Repeat Steps 3-5 to create an "iframe" element for each additional website you want to include. Remember to enter a unique URL in each section of the code.
    7) Save your HTML code and upload it to your active web server.
    You may follow the above steps to combine multiple webpages in one website.
    Alternative: If you are using the Mozilla Firefox browser, you may use install the Page Zipper Add-on to combine multiple webpages.
    link to download the Add-on:
    https://addons.mozilla.org/en-US/firefox/addon/11284/
    Jun 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
    Scanning multiple pages
    Go to the Epson web site and download the Reference Guide that they provide free. This guide includes instructions on using the scanner in Professional mode so you scan multiple images simultaneously
    Jul 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
    983 people viewed this tip
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
