Tip & How-To about Video Game Consoles & Games
How to set up your xbox media center with your pc media center
Go to my computer right click on the hard drive then select properties then click on the sharing tab and click on advanced sharing, then click on share this folder then, ok, apply, ok, then click start at the bottom left of the screen, control panel, network and internet, network and sharing center,
then change the following settings.
network discovery= on
file sharing=on
public folder sharing=on (password required)
password protected sharing=on
media sharing=on
then do the following:
start your media center on your xbox and start the set-up process until you get the extender code, then go to the media center on your PC and go to tasks, then scroll right to add extender click on it and then follow the set-up process.
Video Game Consoles & Games Logo
writeprotected pen drive not formate
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if
you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options
select the security tab option then advanced make sure you have full control in windows 7
click start click to open on my computer you should see your Hard drive C: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Hard Drive (It should be C:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Dec 08, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
usb write protected
Click permissions
hope this helps you
Nov 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Open write protect
Click permissions
hope this helps you
Oct 29, 2011 | Computers & Internet
every time i try to format my 120 GB hard drive its says there is a problem performing that action
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7 this will also apply to usb drives
right click on your usb drive select properties select sharing then select advanced sharing make sure there is a tick in the share this folder box
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F: D: or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right click on your usb drive select format
if you need more help with this post a reply
hope this helps you
Oct 21, 2011 | AGPtek 120GB Hard Disk Drive HDD for...
I have a 500 GB Hard Bbasord protected Hard type
Click permissions
hope this helps you
Apr 09, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
570 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
