Tip & How-To about Computers & Internet
Quick launch in Windows 7
Here is what you need to do to enable quick launch in Windows 7:
Step1: Right click on Taskbar at the bottom -> select "Toolbars" -> click on "New toolbar..."
Step2: In the "folder" line in new window that opened up type in te text below:
"%userprofile%AppDataRoamingMicrosoftInternet ExplorerQuick Launch" (without quotes)
Step3: After typing in the text above click "Select Folder".
Step4: Now you should have "quick launch" at the bottom right and you can now right click the dotted line next to "quick launch" and drag it to your desired position.
I personally like it next to "Start" button just like the old days :-)
Amar Sondhi
Computers & Internet Logo
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
Get back the Quick Launch bar Windows 7's new taskbar functions as a program launcher as well as task switcher. As a result, the old Quick Launch bar, the area on the left side of the taskbar that contained shortcuts for frequently used programs, has been banished. However, if you really miss the little applet, you can add it back. Here's how to do it: 1. Right-click the taskbar and choose Toolbars --> New Toolbar. 2 . You'll be asked to select a folder for where the new toolbar should live. In the Folder text box at the bottom of the dialog box, enter this text: %userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch After you do that, click Select Folder. A link for the Quick Launch bar will be added to the taskbar. It will be on the right of the taskbar, just to the left of the Notification area. It's not particularly useful docked all the way to the right with no application icons showing, so we're going to have to do a bit of work on it to make it useful. Right-click the taskbar and, in the pop-up menu, remove the check next to "Lock the taskbar." Now right-click Quick Launch and remove the checks next to Show Text and Show Title. Once you've done that, drag the vertical triple dotted line next to the Quick Launch bar to the left until you expose its icons. To prevent further changes, right-click the taskbar and check Lock the taskbar. You can now use the Quick Launch bar as you could in Windows XP and Vista, including adding icons to it and deleting them.
Jan 12, 2010 | Computers & Internet
201 people viewed this tip
David Payne
David Payne
