Tip & How-To about Refrigerators
Appliances
Folks,
If you have a power outage PLEASE unplug all of your digital appliances before the power comes back on. Sometimes when the power comes on, it spikes,stutters or is low voltage. This can cause severe damage to digital circutry.
Refrigerators Logo
Defrost light (red light) is on in heat mode and unit not working on heat. Has happened since a power outage.
Good Morning Ray,
I understand that the defrost light is on in heat mode on your Electrolux air conditioner, and your appliance is not working on heat. I also see that this has happened since you had a power outage. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please provide me with the model number of your air conditioner. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Electrolux E23CS75SS Air Conditioner
We had a power outage now the T.V. won't turn back on, there are no lights on or blinking. I can't get it to show any signs of life. What's the deal please help!
Unplug the set for 2 hours then plug it back in. After a power outage when the power returns it will sometimes send tvs into a dumb mode, unpluging will reset the tv to factory settings and it should run just fine
Jan 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
After power outage microwave would not go back on
Have you checked the circuit breaker panel? That could be the problem. Also, with a power outage, when the power comes back on there can be a power surge which can affect appliances. The surge might burn out important components of an appliance. I would check the circuit breaker first. If it is not the problem, you could try unplugging the microwave and then plugging it into another outet. If it still doesn't work, you will probably need to take it to an appliance repair shop. If you've had it a long time, you might consider buying a new microwave.
Thank you for responding to my request for clarification. I hope one of these suggestions turns out to be the right answer for your problem. If it is, please let Fixya know by rating my solution. Good luck!
Nov 23, 2010 | GE Kitchen Appliances - Others
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
Won't come on after power outage
Sometimes you have to unplug the monitor from the power supply and wait at least 30 seconds before plugging back in, and make sure you don't need to press the reset button on the power strip.
May 07, 2009 | Computers & Internet
217 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
