Tip & How-To about Computers & Internet
Windows 7 slow login
Windows 7 Slow Login
Are you stuck in this window for a very long time???
I came across this problemafter I install my Windows 7 on my notebook. I am so excited to get ahold of my windows 7 at that time and then I sense something is notright. When I log-in to my account, I noticed that the loading takes around 20 seconds. I was not convinced that this is a hardware issue because I have all the drivers installed.
As I was surfing the internet, I saw a theme for Windows 7. I install it just to try it then suddenly when I tried to restart, I noticed that the login time speed up drastically.So I surf the internet why does this happen and come up with an answerthat the login problem in Windows 7 is cause by the Desktop Background.
How to fix Windows 7 slow login / start up:
The solution is you have to change you desktop background from a "Solid Color" to any background that you like. If you really like a solid color background, you can do a workaround by creating a solid color image using Paint or Photoshop then set it as a Desktop Backgound. I don't know what is the connection of it but this solution really works. ^^
Hope that this solution help you.
Computers & Internet Logo
Toshiba Satelite A150-S4184,Hasent been used much,It was verry fast, now have internet again and loads very slow and takes long time to load pages,I think auto downloads instales windows 7,What can I
How much memory do you have in your Toshiba Satelite laptop?
Windows XP with Service Pack 3 needs a minimum of 1GB but ideally would run better with 2GB.
Windows 7 would need the same but there is no auto-update process to go from XP to 7 as this is not allowed - you would have to do a Custom install of Windows 7 which requires a clean install (i.e. format the hard drive and start from scratch).
If you are running XP with less than 1GB memory, then you need to check what the maximum memory that the laptop can be upgraded to?
The easiest method is to use the Crucial Memory web site System Scanner utility which will detect how much memory is installed and advise how much you can upgrade to according to the options available for the specific make & model of laptop.
If the laptop hasn't been turned on or on-line for a long time then you may be using a lot of resources downloading Microsoft critical updates plus updates for other installed programs like iTunes, QuickTime, Java etc.
Try downloading and installing a copy of the free Advanced System Care 5 utility then running the Deep Care tools which include System Optimisation and clean-up utilities to improve system performance.
Jan 02, 2012 | Toshiba Satellite A105 Notebook
I forgot my administrative password, whenever i turn on my compaq 6220 notebook it displays Power on Password. Please what can I do to remove it.
You can remove the admin password of your locked computer then you can logon as administrator.
A useful tool just like Windows Password Rescuer can perfectly solve this problem.You also can use it to create a new administrator account without login then you can logon directly with the new account.
If your system is Windows 7/vista/xp,you can use "Windows Password Rescuer Personal/Professional'.
If your system is Windows 2008/2003/2000,you can choose "Windows Password Rescuer Advanced".
Jul 27, 2011 | HP Compaq nc6220 Notebook
665 people viewed this tip
David Payne
David Payne
