Tip & How-To about Computers & Internet
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
Computers & Internet Logo
scanner doesnt have a driver for windows 7
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
Jul 18, 2011 | Office Equipment & Supplies
I have a hp4570c scanner but since installing Windows 7 it no longer works. Any suggestions
For that you need to install windows 7 compatible driver.
Click here
Click on above link and download driver for vista it is compatible with win7.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 17, 2011 | HP 4570C Flatbed Scanner
need software for web camera. I updated windows from vista home to win 7 home 32 bit
HI
Install the same installation file for your web cam in xp or vista
in windows 7 too...
its a trick
in which we are installing this driver in windows 7
compatibility mode allows any file on previous versions of windows to be installed in windows 7
For that
>>right click on the file
select properties
check the compatiblity tab
select windows vista
and dont forget to check"Run as administrator"
and apply
Hope this will solve your problem
Mar 02, 2010 | Sony VAIO VGN-NS140E/S Notebook PC
i have recently installed a window 7, but software cd which i have of hp f4288, that is the old version, that is not installing on this window what should i do now/
Its possible that your f4288 software CD only has drivers for Windows XP or older operating systems. Unfortunately they are not compatible with Windows 7. Try going to the HP website and look at the support area for the F4288, see if they have updated Windows 7 drivers or look for Vista drivers if Windows 7 are not available (as Vista drivers are supposed to be compatible with Windows 7). If Windows 7 (or Vista) drivers are not available on the HP website you are out of luck for now until HP releases new drivers.
Oct 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
181 people viewed this tip
David Payne
David Payne
