Tip & How-To about Computers & Internet
Add Remove Programs list is blank -- Windows 2000
Usually It happens due to some virus activity or any corruption in system files. So when you go to Add Remove Programmes, It shows nothing but a blank space.
· To resolve this issue with Internet Explorer 6.0 installed, repair Internet Explorer 6.0:
Click Start, and then click Run.
Paste the following command in the Open box, and then click OK:
rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
Because this command is case sensitive, you should copy the command, and then paste the command in the Open box.
· To resolve this issue with Internet Explorer 5.0 or 5.5 installed, repair Internet Explorer 5.0 or 5.5:
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
If the Add/Remove Programs tool still does not function properly, shows no content, or if you want to try to fix this issue without upgrading to later versions of Internet Explorer, check the following registry keys to make sure that they contain entries:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache
Note If the previous registry keys are blank, the Add/Remove Programs tool may also be blank.
Use the command line REGSVR32 [path\filename] to register each of the following files:
%systemroot%\System32\Appwiz.cpl
%systemroot%\System32\Mshtml.dll
%systemroot%\System32\Jscript.dll
%systemroot%\System32\Msi.dll
Program Files\Common Files\System\Ole DB\Oledb32.dll
Program Files\Common Files\System\Ado\Msado15.dll
%systemroot%\System32\Msdart32.dll [not registerable]
%systemroot%\System32\Mshtmled.dll
%systemroot%\System32\Mswstr10.dll [not registerable]
If the Add/Remove Programs tool displays incomplete information or is blank, verify the file dates. Where possible, register the following files:
%systemroot%\System32\Gdi32.dll [not registerable]
%systemroot%\System32\User32.dll [not registerable]
%systemroot%\System32\Msvcrt.dll [not registerable]
%systemroot%\System32\Ole32.dll
%systemroot%\System32\Shlwapi.dll [not registerable]
%systemroot%\System32\Imm32.dll [not registerable]
%systemroot%\System32\Indicdll.dll [not registerable]
%systemroot%\System32\Urlmon.dll
%systemroot%\System32\Version.dll [not registerable]
%systemroot%\System32\Lz32.dll [not registerable]
%systemroot%\System32\Comctl32.dll [not registerable]
%systemroot%\System32\Clbcatq.dll
%systemroot%\System32\Oleaut32.dll
%systemroot%\System32\Mlang.dll
%systemroot%\System32\Shell32.dll
%systemroot%\System32\Shdoclc.dll [not registerable]
%systemroot%\System32\NetapI32.dll [not registerable]
%systemroot%\System32\Secur32.dll [not registerable]
%systemroot%\System32\Netrap.dll [not registerable]
%systemroot%\System32\Samlib.dll [not registerable]
%systemroot%\System32\Ws2_32.dll [not registerable]
%systemroot%\System32\Ws2help.dll [not registerable]
%systemroot%\System32\Wldap32.dll [not registerable]
%systemroot%\System32\Dnsapi.dll [not registerable]
%systemroot%\System32\Wsock32.dll [not registerable]
%systemroot%\System32\Plugin.ocx
%systemroot%\System32\Wininet.dll [not registerable]
%systemroot%\System32\Crypt32.dll [not registerable]
%systemroot%\System32\Msasn1.dll [not registerable]
%systemroot%\System32\Msls31.dll [not registerable]
%systemroot%\System32\Imgutil.dll
%systemroot%\System32\Cscui.dll
%systemroot%\System32\Cscdll.dll [not registerable]
Now Restart your system.. and Voila !!
Your problem is gone..
Computers & Internet Logo
HDD Locked due to Brontok Virus
Download a copy of the AVG Rescue CD (ISO image file or USB image) and burn this to a blank CD (or USB stick) then use this to boot the computer with the virus.
Run the AVG virus scanner and let it remove all detected virus activity.
Jan 12, 2012 | Computers & Internet
The notebook keeps turning itself on and off. When it is on the screen is blank and nothing works. Has anyone else had this problem?
Computer that restart automatically, hang up, do not run until the environment commonly have a corrupted system. Sometimes it displays a message saying your computer cannot load windows automatically due power failure or viruses and also corrupted files, bad track of disk. Usually corruption of files are due to viruses, laptops have a good power management, so power problem has a small percentage of bringing this problem, although you can have hardware problem also that's why it will cause some of your hard wares function abnormally.I suggest you run a system restore if you have one. If you don't you can try reformat your laptop. Usually when you buy a laptop you will be given a windows xp or vista cd that you can use as your installer in case this problems occurs. It also has a recovery disk for your drivers sometimes the drivers itself has it. It depends on the manufacturer what they provides. If the problem keeps coming back after you done the above solution you may have a hardware problem i suggest you take some free check for you laptop so that you can solve your problem.
Mar 06, 2010 | HP Compaq Presario F730US Notebook
my widows xp explorer dosent open
your windows installer was corrupted that why its asking open with , so if you windows xp cd which came with your laptop insert the cd and while installing it will show repair option(2 times it show 2nd time u click R) it will repair the operating system and your installer will back ** data will corrupt everything will be safe
Mar 09, 2008 | HP Pavilion dv6000z Notebook
Add/Remove program
If your talking about the listed programs on your machine in Windows Add/Remove? If youve done a restore and nothing has happened then the computer is only listing whatever programmes youve installed. In other words if there are six programmes installed it will show only those six. It cannot possibly show anything or something other than that. If your sure you installed a particular programme and it didnt show up then you need help from Microsoft. They are display in that area for a purpose either the user wants to repair a software or uninstall it. Have I misunderstood your initial help?
Sep 06, 2007 | Microsoft Windows XP Home Edition
203 people viewed this tip
David Payne
David Payne
