Tip & How-To about Audio Players & Recorders
Your coby mp3 wont power on?
Just hit the reset button and it should fix it
My screen won't work.
Hit the reset button on the back, lower right. If you can get the "settings" icon open and hit "calibrate" that will fix it too. I would still calibrate the screen after you hit the reset button to help prevent this from happening again.
Jan 09, 2013 | Visual Land V-Touch Digital Media Player
Why do I have to keep hitting the reset button to get the heat?
If the switch keeps popping, that means there is a problem that the switch is keeping from causing anything from a complete failure to a house fire. As you have asked about a "quick fix", must assume you do not have the required expertise to diagnose the different components. You should call for an appliance maintenance person to come out and fix it instead.
Mar 18, 2012 | Dryers
A message saying waste tank nearly full comes up and i need directions to fix it?
Hello. this message indicates that the computer merely has to be reset [canon is hoping you will take your printer to them for a costly tuneup] here are the steps to reset your counter:
Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
Here is a link where you can download the entire service manual for $4.00. http://www.tradebit.com/filedetail.php/4546475-canon-smartbase-mp360-mp370-mp-360-370
Oct 13, 2009 | Canon SmartBase MP360 All-In-One InkJet...
my camers keeps on asking me to "press the reset switch" and reseting does not seems to fix any problem for me.
I found the fix. It's so easy.
Take out the battery
When it says hit the reset button, hit the reset button.
Turn the camera to off
Wait 2 minutes
Put the battery back in.
Turn on the camera. It won't say reset anymore.
Jun 30, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
image go off
I have had the same problem. I've just managed to get the monitor working again by VERY QUICKLY navigating through the monitor setup menu to the 'factory reset' option and hitting reset before the screen had a chance to blink off.
The problem I had is that the monitor suddenly goes black, but will come on for five seconds if I switch it off and on with the power button.
In that five seconds, I had to...
>Hit the menu button
>then hit the '+; button once
>then hit the menu button again
>then hit the '-' button
>then hit the menu button one last time
The above brings up the menu, scrolls up off the top of the list to the last item on the list (Factory Reset), selects Factory Reset, selects 'All settings' and resets the monitor.
I don't know if this is a permanent fix, but it just worked for me and mine has been doing this intermittently for the last week.
Give it a try, it's frustrating and will take a few tries, but it can't hurt.
Oct 27, 2007 | Dell E173FP 17" LCD Monitor
172 people viewed this tip
 Grubhead
Grubhead
