Tip & How-To about Audio Players & Recorders
Solutions to watch Blu-ray movies on Mac and WD TV
Not an easy thing for Mac users to play back Blu-ray movies, even they are your personal purchasing. I’ve summarized three ways that Mac users have usually used to playback Blu-ray movies as following. Frankly speaking, the former two solutions seems a little troublesome, personally, I prefer the last one.
Solution 1: With the help of AnyDVD HD via Windows:
Requirements:
- A Windows PC with a built-in Blu-ray drive or an external BD drive.
- AnyDVD HD
- A Mac: MacBook, MacBook Pro, MacBook Air, iMac, or Mac Pro
- Latest VLC media player or MPlayer
How-To:
1. Insert your Blu-ray disc to the BD drive, and run AnyDVD HD to remove copyright protections of your disc, no matter what kinds of protections your BD discs adopted, BD+, or AACS, AnyDVD HD is capable of dealing with them. Then you will get unprotected.m2ts files after the access of AnyDVD HD.
2. Copy the .m2ts files to an external drive or a USB stick, whatever, just let the Mac be able to read them.
3. Use the latest VLC media player or MPlayer to play unprotected .m2ts files.
Solution 2: Running Windows on Mac via Boot Camp
What you will need:
- A BD drive
- A Mac
- Blu-ray playback software on Windows, like Cyberlink PowerDVD 9 Ultra
How-To:
1. Install Boot Camp and Windows
I do not mention too much about this process, because Apple has already given the full direction about it here.
2. Connect BD drive with your computer, and Playback Blu-ray via PowerDVD 9 Ultra on the newly installed Windows OS.
Solution 3: Rip BD with Pavtube Blu-Ray Ripper for Mac
What you will need:
- A BD drive
- Pavtube Blu-Ray Ripper for Mac
This ripper provides directly copy function as well as HD video output option, so there is no need to worry about the output file quality of your Blu-ray movie.
The above two methods are all depending on the assistant of Windows, while the third one is not, thus I’d like to show the detailed operating steps about this one in detail.
Easy-to-use steps:
1. Load BD files through "DVD Folder" or "IFO File".
2. Select audio track from the pull down menu of "Audio", both Dolby TrueHD audio and DTS-HD Master Audio are supported.
3. Click the drop-down list of "Format" to select output format. Directly copy, HD video, iPhone, iPod, PS3, and many other devices and formats are all supported.
4. Click "Settings" button to adjust audio and video parameters like codec name, bit rate, aspect ration, frame rate, sample rate, and audio channels(5.1 channels is included).
5. Click "Browse" button to specify save path.
6. Click "Convert" button to start conversion.
Once the conversion is done, you are able to find out the output files via clicking "Open" button. If you choose directly copy, you can use VLC or MPlayer to play the output .m2ts files, if you converted to other usual formats, like mov, mp4, then you can use QuickTime player or whatever to play back them.
Via the Blu-Ray Ripper for Mac mentioned in solution 3, you can also absolutely realize playback BD movies on your HDTV with WD TV. Both WD TV Live HD Media Player and WD TV HD Media Player are all workable with .m2ts files, and they also support Full HD resolutions up to 1080P in common. In order to reserve the HD audio and video quality of your BD movie, you can completely select "Copy"> "Directly Copy" to just get the .m2ts files as the original as long as your USB device has enough space to store the output files. If not, you can also consider converting BD to a HD video format to save space as well as keep HD quality of the source file.
Well, hope the above contents are helpful.
Put and play Blu-ray/DVD movies for new iPad with Full HD quality Summary: Most Mac users have difficulty to stream Blu-ray and DVD movies to iPad 3. Today, this article will recommend a professional Mac Blu-ray to iPad 3 converter for you. Meanwhile, i will give you a detailed guide to show you how to rip Blu-ray/DVD movies for new iPad 3. Many users like watching movies on new iPad 3 so as to take full advantage of the amazing retina display, but most of them have difficulty to stream Blu-ray and DVD movies to iPad 3. Below is a question about this: "I want to copy and convert my dvd's into my iTunes library on my computer and transfer them to my new iPad, so that I would be able to watch the movies I own on my iPad as I travel. The DVD also includes Blu-Ray. I'm running OS X Lion. What DVD ripping software do you think work best for my need?" There is no doubt that in order to play Blu-ray/DVD movies on iPad 3. A iPad 3 Blu-ray/DVD ripping software is needed. The user running OS X Lion, so he need to choose a tool that can works on the operating system.Pavtube Blu-ray Ripper for Mac is an ideal one.Which is speical designed for Mac users to handle kinds of Blu-ray/DVD movies. This best Blu-ray ripper for Mac to iPad 3 can works on Mac OS X Leopard (10.5), Snow Leopard (10.6), Lion (10.7), Mountain Lion (10.8). Moreover, it is built in presets for iPad, including iPad, iPad 2 and new iPad 3. Which will give you the best video quality on iPad. Now, just follow the guide to converting Blu-ray/DVD movies to new iPad. Step 1. Install the Mac Blu-ray to iPad 3 converter Step 2. Load Blu-ray/DVD movie into it. It supports importing Blu-ray/DVD disc, Blu-ray/DVD ISO, Blu-ray/DVD folder and DVD IFO. Step 3. Choose output for new iPad 3. Click on "Format" bar, you can easily find the "iPad" category. For iPad 3, the " iPad 3 Full HD Video (*.mp4) " is recommended.It's the best settings to rip blu-ray/dvd movies to ipad 3 Step 4. Press "Convert" button to start converting Blu-ray/DVD movies to new iPad 3 on Mac. Step 5. After the conversion is done, transfer the result video to iPad 3 via iTunes. Now, you can watch Blu-ray/DVD movies on new iPad 3 as you like. Good News! In Pavtube 2012 Summer Sale, you can Save 20% to get the Best Mac Blu-ray Ripper for iPad. Don't miss it! 20% off Blu-ray ripper:Blu-ray DVDs to iPad 3 1080p video 20% off Blu-ray Ripper for Mac:Blu-ray movies to 1080p video for the new iPad 3 on Mac 20% off DVD Ripper:DVD ISO to iPad 3 ripping 20% off DVD Ripper:Watch 720p DVD Video on the new iPad 3 20% off blu-ray ripper: AirPlay Mirroring to Stream iPad Movies to HDTV http://www.pavtube.com/blu-ray-to-new-ipad-3.html http://www.pavtube.com/2012-summer-sale.html
I recommend that you will post your question under the correct category and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
Aug 15, 2012 | Camping, Backpacking & Hiking
Aunsoft Blu-ray to iPhone 4 Converter-Convert BD/DVD to iPhone 4 With iPhone 4 on hand, do you want to make full use of your Blu-ray disc and DVD disc, and have them playing on your iPhone 4? Aunsoft Studio announced Blu-ray Ripper for Mac as the Mac Blu-ray to iPhone 4 converter for iPhone 4 users to enjoy HD 720p videos. The Mac Blu-ray to iPhone 4 converter has been updated with enhanced iPhone 4 profiles to make it easy operation on iMac/MacBook Pro. Load BD/DVD movies via 3 methods: 1. Quickly load BD/DVD disc from BD/DVD Rom with one click. 2. Load movies from BD/DVD-Video file structure folder, which are saved as backup copy. 3. Load BD/DVD image ISO, or DVD IFO for particular part of movies. Convert BD/DVD to iPhone 4: With the flexible movie loading method, you can rip Blu-ray to iPhone 4, convert Blu-ray ISO to iPhone 4, convert DVD to iPhone 4, DVD ISO to iPhone 4, and DVD IFO to iPhone 4 with perfect video and audio synchronization. Why choose Mac Blu-ray to iPhone 4 converter? - Hard burn subtitles to iPhone 4 videos. - Convert BD/DVD main movies to iPhone 4. - One click to choose perfect video playback on iPhone 4 with 720p - Downscale 1080p Blu-ray disc movie to 720p for iPhone 4. - Upscale SD DVD to HD 720p for iPhone 4 H.264 .mp4. Download Mac Blu-ray to iPhone 4 converter, and the BD/DVD to iPhone 4 converter will help you remove copy protection for easy playback on iPhone 4. The Mac BD/DVD to iPhone 4 converter also enables you to convert BD/DVD to other formats as you like.
Jul 06, 2010 | Cameras
My DVDXCOPY Platinum will not activate after inputing the License ID# and Password. Can anyone help please?
DVDXCOPY has been shut down for many years, their are a few people still selling it knowing it can't be activated. Their were a few sites that carried activation codes that worked. In all reality its not a very good program, I started out using it and switched to DVDFAB Platinum and haven't found anything it wouldn't copy, it also shrinks long movies to fit on a 4.7 DVD.
Aug 19, 2009 | 321studios DVD X Copy Platinum (200000)...
Mac Blu-ray to iPad Converter - Best iPad Blu-ray Converter for Mac users Best iPad Video settings Follow the optimal settings to get excellent playback quality. Video: Codec: H.264 Size: 640*480 or 1280*720 Bitrate: 2500kbps Frame rate: 30fps Audio: Codec: aac Sample rate: 48khz Bitrate: 160kbps Channels: Stereo Pavtube Mac iPad Blu-ray Converter v2.6 is a powerful tool specially designed for Mac users to rip, convert, backup and edit both Blu-ray and DVD movies. The source movie could be from Blu-ray disc, DVD, Blu-ray and DVD folder, DVD ISO and IFO file. The ripper could remove all the protections of Blu-ray and DVD movies , back up the movies to hard drive, rip and convert them into other popular audio and video formats to playback on your beloved portable devices such as iPad, iPod, iPhone, Zune, Blackberry, PSP, Creative Zen, Xbox 360, Apple TV etc. Besides, the M2TS files can be imported to Blu-ray Ripper for Mac and converted to compatible formats for editing in video editing software like iMovie, FCP, Avid etc. Blu Ray Ripper for Mac features powerful editing functions and customization. You can trim and crop the video to any size and any length, adjust the video effect, replace the original audio with your favorite music, add watermark to make your video different. More specific video and audio parameters such as frame rate, bitrate, sample rate, audio channel are available for your enjoyment as well. The lastest updates improved the program to capture any of the Blu-ray subtitles and audio tracks. Even 7.1 channels is available. You may also back up the whole Blu-ray disc/ DVD to hard drive with one click. What's new - Added the option of one-click Full Disk Copy, enabling users to make 1:1 copy of Blu-ray disc and DVD. - Added support for Blu-ray disc of MKB v17. - Improved the loading speed of Blu-ray disc/ folder. - Added customized output formats for iPad. - Refine the GUI to be more user-friendly, and apply Deinterlacing facility by default. For Windows user: Windows Blu-ray to iPad Converter Learn more: Best iPad video conversion tools
May 12, 2010 | Cell Phones
129 people viewed this tip
 Grubhead
Grubhead
