Tip & How-To about Plumbing
Tips on Solving Common Toilet Problems
Water Trickling Into the Bowl The solution is to drain the tank and bowl, check and clean the flapper seat, and replace the flapper if it's worn or damaged.
Plumbing Logo
Please tell me how to replace the gasket on the flapper assy.
flapper.jpgFlapper or flush valve needs servicing
First try cleaning minderal deposits from around the valve seat. This can keep the flapper valve from sealing properly and allow water to seap into the bowl. First turn of the water and flush the toilet to empty the bowl. You can unhook the flapper valve to get it out of the way. Using emery cloth scrub the inside of the valve seat to remove the mineral deposits. Next coat the valve seat with petroleum jelly to help the flapper valve make a tight seal. Replace the flapper valve, turn on the water and check to see if the water still leaks.
If the flapper valve is old it may be deformed. In this case you will need to replace it. You can unhook the valve and remove the lift chain from the valve. Be sure to purchase a similar size replacement valve.
If the valve seat is damaged you will need to replace the entire flush-valve assembly. You will need to remove the tank to do this. Be certain to turn off the water supply and flush the tank to drain it. You might also want to place newspaper and towels on the floor to soak up any water that may leak out. Using and adjustable wrench loosen the nuts at the supply tube and push the tube aside. Next, use a flat-head screwdriver to hold the bolts inside the tank still while using an adjustable wrench to loosen the nut on the bottom of the tank. You will then be able to lift the tank off of the bowl. Lay the tank on the newspapers or towels.
To replace the flush-valve assembly first remove the old one by unscrewing the locknut on the bottom of the tank. Use a hacksaw to cut the new overflow pipe to 1/2 ince below the tank top. Put plumber's putty on the washer at the base of the flush-valve assembly and push the assembly against the tank opening, removing any excess putty. Use a monkey wrench to tighten the locknut. Replace the gasket over the locknut and replace the tank on the bowl and reassemble them.
Jun 15, 2011 | Kohler - Toilet - Two-piece - Highline -...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone. The flapper appears to be seated well and no sign of leaking. What is causing the water to drain from the bowl like this?
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
When I flush the toilet, water fills the bowl. After about 30 minutes, the water drains from the bowl completely.
Attached to the Flushvalve is a rubber stopper commonly called a flapper. If the flapper is worn this would cause the problem. Also sometimes the chain that attaches the flapper to the handle gets caught and the flapper sdoes not seat right. Check this, if it is clear and not obstructed try repalcing the flapper.
Feb 02, 2011 | Jacuzzi Home
refill water doesnt stopkeeps running
could be that the flapper is not seating properly and lets the toilet tank slowly drain into the bowl..
clean flapper and drain to toilet in tank and verify for proper seating.
if it still runs, my opinion would be to change flapper.. (if new enough, then under warranty)
Aug 02, 2010 | Caroma Home
pump cycles often
The following are the possible problems and solutions:
  1. The tank flapper (Flush Valve) leaking allowing water into bowl. Make sure flapper is fully seated. If flapper is fully seated and still is leaking replace flapper.
  2. Faulty Non-Return Check Valve, water leaking back into Macerator. Clean and Inspect check valve replace if after clean water still flows back into Macerator.
I hope this answers your question and gives you a few more places to look. Please rate the answer on it's helpfulness. Good Luck and have a great day. Jeff
Apr 06, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
368 people viewed this tip
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
