Tip & How-To about Computers & Internet
Changing themes on Windows XP.
So, here we have a simple guide on how to change your normal windows look and how to install a custom theme which you will find many online.
Here is our original windows xp themed start menu and desktop.
First to install a new theme you first have to obtain one, here are a few
After you have downloaded the zip file containing the theme. Double click on the file to open it.
Now, this may look different on your pc, it depends if you have installed a program to extract zip files. If you are familiar with zip files etc just extract the files and run the setup to install the theme.
Inside the zip file you will find the following
Double click on the setup file to install the theme.
you may get a pop-up asking for you to extract all, run or cancel, click on run if you do. if asked again, click run again.
Basically install the theme just by clicking next next next and finally finish.
Once you have installed the theme, right click on your desktop background and select properties.
On the properties / theme page, click open the list of themes and select Royale from the list, then apply and OK.
And here is the new theme we downloaded:
You can obtain different themes from all over the net, I would suggest you go with the site linked here, scan the files for viruses before installing. Good luck and thanks for reading.
Computers & Internet Logo
how to change themes
this video should help you with Worpress themes
Mar 11, 2012 | wordpress.org
how can i change the theme of my cellphone the black one with transparent like blocks or squares like that. thak you
You can search online for new themes, download them and install it in your smartphone.
For exemple, in this link http://forum.xda-developers.com/showthread.php?t=489108
you have two themes and the further explications on how-to-install and in the same forum you have many others themes and the how-to-install guides.
Mar 22, 2011 | HTC Touch Diamond Smartphone
Vista Appearance changed to 98 style in the windows and start bar only. Custom background is still present but it's all light grey as in windows 98. This has happened after the first time of turning the computer on after 4 updates were installed. How can I restore the default Vista theme?
Ok, this should fix your problem.
1.Right click on an empty spot on your desktop
2.Left click on "Personalize" from the menu
3.Select "Themes" from the personalization window
4.Choose "Windows Vista" or "My Current Theme" from the dropdown and click "OK".
Your screen will go Black and White, then return to normal. Look forward to hearing back from you soon.
Feb 24, 2010 | Microsoft Windows Vista Home Basic for PC
i want to change my themes in my nokia 6300 china phone!
for changing themes frst download themes to ur phone then u have to install it and then apply it simple
Aug 10, 2009 | Nokia 6300 Cellular Phone
how can i download themes for xp?
there are several ways to install themes on xp.
1. by installing a third party software which will spice up ur OS big time.But at the same time many have faced issues concerning OS crashes by doin so.
2.Jus download normal xp themes and apply by right click-->themes.
If u wanna try third party softwares go to   http://www.themexp.org/
or else try   http://customize.org/xpthemes
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
280 people viewed this tip
David Payne
David Payne
