Tip & How-To about Video Game Consoles & Games
How to play a scratched disc on xbox 360 or some other consoles
Note: I have only experienced using this trick on the XBox 360 Console.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
Video Game Consoles & Games Logo
my xbox scratched my game
The first xbox models had the same issue, I my self experienced it, but it was only once.
Replace the drive or talk to microsoft if it happens again
Jun 21, 2009 | Microsoft Xbox 360 Console
New XBox 360 putting scratch in games
the problem is the disc drive.
you have to open it up and put some stick foam " like a sticky strip of foam, insulator : on top of the drive .
the problem is that the disc touches the laser assembly while turning cheating a ring on the disc.
i can fix your games as well as the disc drive if you feel like is to complicated.
Jan 02, 2009 | Microsoft Xbox 360 Console
video output on wrong setting and cant see screen
for PS3, hold the power button for at least 5 seconds or until you hear a second beep.
for Xbox 360,
Turn the console on.
Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
Note Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts.
Sep 05, 2008 | Video Game Consoles & Games
sound but no picture
turn it on put in gaylo 3 and let it sit for a bit if not then maybe the game is scratched or look at the circle in the middle of the game and see if theres a crack if there is you might wanna buy a new game
Aug 05, 2008 | Microsoft Xbox 360 Console
536 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
